Hi! Wanting to get my auto transmission serviced.
I bought 8L of Castrol Transmax Z from Super Cheap Auto today from their 20% off sale
Newaiz, im not sure how much Litres I need for the service, Im providing oil to my mechanic to put in but they are closed today.
just wondering if its enough?
Anyone know how much Oil I will need flush or not?
And what should I change for my transmission service, so far i got this on the list:
  • Oil
  • Gasket
  • Filter
Also should I change my differentail oil as well? Can the mechanic at a transmission workshop do it? If yes, what oil should I use?
What price should I expect for this service minus the transmax Z oil I already bought
Any help will be appreciated
https://www.sau.com.au/forums/topic/348980-r34-tiptronic-gearbox-service/
hey matey, just went through this recently the workshop i did my service at recommended me to do a new filter ($20) and gasket ($15) these were aftermarket items as i rang around different workshops and Nissan dealers who couldn't help me with it. I paid 80$ in labour and supplied my own oil, i went with Redline High-Temp ATF
You won't be able to flush all the old oil out as that pretty much requires removing the whole gearbox as there will always be liquid in the transfer case, like you i bought 10L of ATF and ended up using about 5L
pretty much that's all that's required, so long as you maintain it every 25,000 kms depending on how you drive you will have no dramas
As far as the diff is concerned you should service that every 10,000 kms, needs a specific diff oil, your mechanic should know more about it
hope that helps mate
danny
danny
Yo! thanks alot man, appreciate your help :)
Diff drain intervals are typically closer to 100,000km than 10,000kms.... If you use fully synthetic you can triple the factory drain interval.
  • 7 months later...
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
