I want to know exactly what temperature the water is, not "somewhere between 65 and 110 degrees" while the needle sits in one spot in the middle.
Before I pull it apart to try fix it, has anyone modified the water temperature gauge to eliminate the inbuilt normalization?
The consult port can give you an accurate digital readout if you have a device which can work with it. I use a Blitz r-vit, which gives me a digital value for the water temp (along with all the other ecu readouts)
http://www.nolimitmotorsport.com/blitz/rmonitor-rvit.html
fyi, This wont work with a powerfc. Only with a standard ecu.
Yep, know about reading and tuning via the Consult port, however I'd prefer the factory gauge to work properly without the addition of aftermarket products that I think look out of place.
Cheers
I was thinking more along the lines of mounting an aftermarket gauge behind the dash, then connecting the factory needle to the a/m one.
Ahh yep, makes sense.
I'll do that if I can't modify the factory motor that drives the temp needle. I'd prefer to keep it since it fits properly for illumination, max and min stops are in the right spot etc.
Cheers
Done - I removed the normalization electronics and calibrated the gauge so it accurately tells me the engine temp. The gauge is linear however the NTC temp sender is logarithmic so higher temps are accurately displayed which suits me perfectly.
Before modifying the gauge, while bench testing the sender and dashboard temp gauge, it begins moving from C when the engine temp is at 45 degrees, hits the middle at 60 degrees, stays in the middle until 110 degrees and reaches the H marker at 130 degrees.
Going from top to bottom
H - 105 deg
--- 100 deg
- 95 deg
--- 90 deg
- 85 deg
--- 80 deg
C - 75 deg
Edited by Bozz
H - 105 deg
--- 100 deg
- 95 deg
--- 90 deg
- 85 deg
--- 80 deg
C - 75 deg
thats real nifty! Should write up a tutorial on how to do this modification.
Although, anyone not knowing the modification has been done will be freaking out that it sitting just above the Cold indicator haha.
My car cruises on 78-84deg so it would be hovering just above the C mark haha
Cars cold start switches at 65degrees, so the gauge wont reflect that as it wont move after 75deg.
what a f**king hassle for a guage that still isn't going to tell you the engine temp
pro tip: defi make good gauges
my water gauge tells me exactly what temperature it is always
Thanks for your input. Keep being totally awesome.
Besides one person before I did the mod, I didn't think anyone wanted it, seems people like adding gauges and shit to their interior. I'll summarize:
I pulled the gauge apart, drew a circuit diagram, bypassed the normalization electronics and then put it back together.
Next, I pulled out the temp sender, put it in a small pot and covered it in vegetable oil (coz water boils at 100 deg) and put it on the stove. I heated it and measured the temp vs resistance as it was cooling down (to get a more accurate reading) and plotted a graph - compared to the R32 factory manual, my sender was reading low by about 15%. I then used a 10w variable resistor to simulate temperature and modified the electronics to read what I wanted as minimum and maximum. Put it together and all is sweet :)
haha sounds awesome. Good job
Nice work. I also like to keep things relatively stock inside, and was wondering what the water temp is when it's sitting at the middle of the guage the whole time.
Might as well remove the gauge and put a light there to tell you it's either cold or overheating (Tiida) :P
It does take a lot of time and effort to do something like this, so thanks for sharing.
Well shit eh... if I pull the dash apart for any reason again in the future, I'll take pictures and do a quick write up.
I thought I was the only one who wanted his car looking stock :)
Cheers
i think its more about having a useful in-dash gauge, rather then having absolutely no warning before hitting 100 degrees and blowing a head gasket.
if nissan provided a useful gauge, i believe it would have saved thousands of blown head gaskets around the world.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
