Nope, around $1100 trade.
But by as they come with wheels (cartridge assembly), labour/balancing to remove and refit given the 3037S is not a off-shelf cartridge IIRC, it'll probably be around 1600-1800 total rebuild price from a reputable rebuilder.
Could be more, but i doubt it'll be any less
so ur saying it would cost me more than to buy a brand new turbo?
so if i can get the turbo for $500 im coming up even, then ive gotta pay for it to be shipped down there and back...and then the labour
Edited by jamie curran
If you can buy a HKS 3037S for $1800, i'll buy 10.
The turbo you have can ONLY be purchased with the cartridge/CHRA. They are not rebuildable.
You purchase the whole thing and it comes with front/rear wheels. You need housings then, actuator etc.
I could be wrong and making a dick of myself but.....
Uploaded with ImageShack.us
and another
http://www.turboaust...turbos.ewdid=13
and another
He said a HKS 3037s, those are the Garrett versions, HKS get them off Garrett and alter them for even better response/power.. etc... thats why HKS call it a 3037s and Garrett call it a 3076r
As above, that is not a 3037S
Pretty sure the 3037S (HKS) was the only 3076 series to come with a certain size wheel trim.
Its trivial at best in terms of performance gain however, but there is no way they are $1800 new. Only HKS have them 3037S
ok now that we are on the same brainwave, i would be better off buying new Garret GT3076R for $1750 than buying a 2nd hand HKS 3037S and getting it repaired and costing me maybe more....
In reality a Garrett GT3076R is a HKS GT3037S without the bell mouthed insert piece and a HKS turbine housing .
In recent years you could get the 52 and 56 compressor trim versions ex Japan and the matching port shrouded compressor housings as well .
HKS added their own unique bits to an as supplied Garrett turbo , it would not be cost effective for them to buy turbochargers and alter them . They'd have them made to spec which they do/did .
A .
As above, just to confirm that the 3037S core is the same as the garrett item. Both the 52 and 56 trim CHRA can be purchased new from GCG.
The unique items added to the turbo by HKS are the housings. If you were to pick up a busted 3037S WITH THE HOUSINGS for the right price, provided you can still use the housing (not damaged when the turbo blew) you will be able to replace the CHRA with ease.
Both 56 and 52 trim versions available from GCG for under $1400 retail:
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=161&category_id=28&option=com_virtuemart&Itemid=53
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=231&category_id=28&option=com_virtuemart&Itemid=53
The HKS "S" suffix should denote that it runs a "free floating" spec that requires an external gate.
A "Pro S" suffix denotes an internally gated turbine housing.
I sourced a Pro S housing and used it with an assembly sourced new from Garrett. As Adrian said, it comes without the bell mouth insert but otherwise it's the same unit.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
