Hey guys,
Unfortunately my car has developed an exhaust leak today, and it has gotten louder over the day and the car has become very sluggish.
Its not the normal high pitched squeal and I have checked the turbo and when I turn the car off I can hear the turbo spinning freely without any problems so I know the turbo is fine.
I have an external gate welded on the back of the turbo, but have felt around the weld for air/sound and it is fine.
The best way to describe the sound is like an unmuffled exhaust, as in no exhaust at all, just not as loud.
I have put soapy water and normal water all around the manifold and cant see any bubbles, my guess is its at the back/bottom of the manifold.
Later tonight when it has cooled down I will get under the car and see if I can see/hear anything further.
question:
Where in the Eastern suburbs can I get it checked/repaired? I was thinking Performance Exhaust in Ringwood, any other suggestions?
Thanks, Adam
https://www.sau.com.au/forums/topic/349702-exhaust-leak/
Got under there last night, found this, sprayed it with soapy water and i was blowing lots of bubbles, so I was spot on.
Went to performance exhaust today, Dave was very honest and admitted 1. They can't weld cast - or atleast it would not hold for long. 2. they can't weld upside down, so the whole manifold would have to be taken off.
Now sourcing parts, getting a fancy gasket and other bits from the states from the recommendation of Dr drift.
If anyone has a R33 Turbo exhaust manifold in good cond please let me know :)
Thanks very much for the help guys.
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5618441
Whats your exhaust like - seems that the weight/heat combo has caused a crack.
Very rare to see a manifold crack like that.
Ensure you change all the manifold studs as well. Likely 2-3 will break when taking the manifold off anyway
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5618495
well, I did try one of those heat wraps, pain in the ass and F*ing itchy to put on, pretty much useless, took it off to find this crack with a stanly knife, never putting anything like that rubbish on the car again.
So the crack did form with the exhaust wrap on, had it wrapped for about 6 weeks, still I find it hard to believe it cracked....
the only other thing I can think of is that because of the small .63 bum on the turbo and 19psi? I did have that thread awhile back about the extremely hot intake and that going the 0.8x housing would allow more flow and stop the turbo heating up?
is that maybe something I should look into to stop this happening again?
The exhaust is very comfortable on the back of the turbo, not stretching or pushing into it when it sits freely - about 2mm off the turbo. front/dump pipe does have a flexy join in it to reduce tension even further and the momo course cat back.
oh and I anticipate I will have to call the thread doc out :)
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5618671
Mate I changed my manifold 3 times in 2010. It's not all that hard, just a pain in the bum.
Coat all the nuts in wd40, wait an hour, coat them again. Let it sit for an hour or so, then have a go at them.
You will be able to get a manifold from the wreckers (osaka imports) $100-140 + nissan mani gasket $110 (kudos motorsport) + turbo gasket & crush washers $50 (kudos motorsport).
My first one.
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5619136
I know its not that hard to change, just a pain. If the heatwrap can cause this that would be a bit of a relief so that at least i know my actual setup isn't causing this...
that crack is massive, what was the cause?
I called osaka imports, $120 for the manifold, Sam will get one for a lot cheaper if I cant find one for 50-70 bucks in the mean time on here.
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5619175
The dump was heat wrapped for that one and running the standard r33 turbo @ 12psi.
The other two didnt crack, just warped with no wrapped at all and 21U highflow @ 14psi. In saying that
the car sees only track work.
When you pull the mani off, make sure the exhaust housing is still flat.
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5620302
Got the manifold off and the studs out... unfortunately 2 broke in the block but i'll get in contact with the thread doc.
I'd like to mention how much easier wd40 made getting the nuts off, I sprayed it in the morning before work and they looked all rusty, by the time i got home that night they looked shiny again and all came off fairly effortlessly.
my next question: When i get my new manifold, where can I get it heat coated, does it improve engine bay temps/prevent cracking and how much does it cost roughly?
post-36975-0-98837500-1295044952_thumb.jpg its more then I thought, that crack goes right in there. I have checked flanges with a metal ruler and they are perfect.
Adam
https://www.sau.com.au/forums/topic/349702-exhaust-leak/#findComment-5625692
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
