Hahaha didn't realise you didn't have your brackets yet.
I will hopefully get a chance over the Easter weekend break to fit my kit so will post up pics then.
So tempting to chuck them on tonight to have them ready for the Airlie Beach cruise on the weekend....
Just don't want to break something and then not be able to go. Knowing my damn luck that is exactly what would happen :(
Had a crack at it this arvo and came to a hault pretty damn quick, you've gota thread out the paint from the rotor hat coz it's so damn thick the bolts won't go in to attach it to the rotor itself, so gota go buy 1 of those tomorrow
I see what you mean about the rotor hats. That sucks. Looks like I can't install them today because I don't have an imperial tap and die set and everything is closed :(
Also here is a bit of a DIY install for a 240SX from Wilwood. Good to use as a guide any way.
http://www.wilwood.com/Pdf/howtostories/Nissan_240SX_Brake_Install.pdf
AND IM DONE!
Just waiting on the missus to come home from uni so she can help me bleed the brakes lol. In the mean time I'll start writing the DIY up. Went fairly smoothly.
Also was very impressed with the weight! Will reveal all in the write up :D
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
