better off going for the GT3076, there isn't that much difference at all.
Plus you have that head room... 280rwmw isn't that great... lol
Its all relative, if your used to the stock 140rwkw it IS great!
Plus if its a street car the more responsive turbo will be better in most cases.
https://www.sau.com.au/forums/topic/350376-3076r-or-3582r/#findComment-5625780
what the fuck are you smoking man? 280 rear wheel megawatts is PHENOMINAL...
in a gtst that's roughly 207,500rwkw/tonne
ok... i'll add IMHO to my post ;)
https://www.sau.com.au/forums/topic/350376-3076r-or-3582r/#findComment-5625862
Agreed...280 jigga watts is plenty...especially when coupled with an atmo bov... :P
https://www.sau.com.au/forums/topic/350376-3076r-or-3582r/#findComment-5625898
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
