Condition: Used
Reason for Selling: want to get rid of parts
Asking Price: 5
Delivery Methods: PickUp
Contact Info: pm, 0419761510
Extra Information:
Hey guys i have decided to rid my self of all the skyline parts and nissan parts i have accumulated over the last few years. All parts listed below are $5.00 each and it is first in best dressed! cheers guys, Hame rolleyes.gif
R32 Skyline
- R32gtr rear rotor (single)
- R32 gts-t front hard metal brake lines with fittings
- R32gts-t rb20det OEM turbo charger (blown exhaust wheel)
- R32gts-t rb20det dump pipe
- R32gts-t rb20det turbo elbow (off compressor housing)
- R32gts-t rb20det Timing belt cover (embossed rb20 & includes dust cover)
- R32gts-t rb20det OEM throttle body
- R32gts-t rb20det coilpack brackets x 2
- R32gts-t rb20det OEM intake manifold (with everything – valves)
- rb20det afm(unknown condition)
- r32 rb20 standard cam gear
- r32/33 turbo heat shield
- 2 rb20 coilpacks
- rb20det charcol canister
- R32gts-t Air-conditioning grille & line
- R32gts-t rear cradle supports
- R32gts-t gearbox cross-member
- R32gts-t rear tailshaft (centre – diff) x 2
- r32 gtr dash cluster - minus tacho
R33 Skyline
- r33 rb25det coil pack cover x 2
- r33 rb25det brake filler bottle
- R33gts-t air-conditioning grille
- R33gts-t Rear left tail light (painted green)
- R33gts-t door rubber seals (no splits or perishes)
- R33gts-t centre consol
- R33 hazard and dimister button
- R33 climate control unit
- r33 front bar indicator (left side)
- r33 quarter pannel indicator (right side)
- r33 Smart Entrance box
- r33 clock
- r33 indicator stalk x 2
- r33 roof handles $2.00 each x 4
- r33 dash vents <- near windscreen
- Many Interior plastic panels (enquire for price & availability)
- R33gts-t rear seats (both sections, great condition)
- R33gts-t Dash (no cracks)
- R33gts-t rb25det VLSD Diff (wines a little, suit drift)
R33 boot gas struts
- r33 bonnet release cord
- r33 engine bay fuse box and loom
- r33 charcol canister
- r33 horns
- r33 fuse box lid
- r33 radiator supports pair
- r33 wiper motor
- r33 bonnet relase catch, bonnet clip <- bit of metal down the front has horns attached x 2
- R33 gtr rear spoiler (damaged, requires fibreglass)
- R33 rear pods (unknown make, one damaged)
- side door plastics 'skyline' embossed (sill trims)
- steering wheel surround plastics
I know there is no pictures posted here in this add, as u can imagine it would take forever to take them all and upload them so if you require photo's request the part you want and i'll send them to you some how or post them up! Also have more parts available so just ask please and i'll respond when i can! Pick-up can be arranged once contacted. Kind regards, Hame!
https://www.sau.com.au/forums/topic/350403-the-5-skyline-part-sale/
  • Replies 51
Do the boot gas struts for R33 work fine? Mine are a bit weak so wouldn't mind replacing them. Do you have the "tweeter triangle plastic bits" that sit on the inside of the car where the mirrors bolt on?
Do you ever come down to the gold coast?
hey there nah i not coming down the coast sorry, not 100 percent sure about the gas struts have never installed them. ill check about the triangle bits, you dont mean the pillar by any chance? hame
Hey mate no i dont have the shifter surround that has sold! Also to ash s13 i have the release but no horns now, horns sold.
as did:
1 x coil pack cover = $5.00
1 x tail light = $5.00
1 x hazard and dimister button = $5.00
2 x wiper stalks = $10.00
1 x indicator stalk = $5.00
1 x fusebox = $5.00
2 x sill trims = $10.00
1 x steering wheel surround plastics = $5.00
1 x clock = $5.00
2 x kick plannels = $10.00
cheers guys!
Edited by H@ME
have you still got the R33 hazard and dimister button? also the RH plastic that goes up the roof from the front window. and the centre unit that has the lift up compartment between the two seats? are all $5 if available?
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
