How come the one with -9s has boost control issues?
I'm curious on how -9s with boost control issue fixed would stack up compare to -7s in terms of response.
Don't know. Mate of mine said mine was quite a bit more responsive than his, given our turbos are similar, we now know why.
No doubt he'll get it fixed eventually. Could be 100 things.
Ash, great effort on the comparo this is exactly what makes this site useful.
I'm looking for turbos at this stage and your turbos seem very appealing, theyre more responsive and overpower the 9s. Boost issues aside, the 9s seem to be behind these hybrids by some way.
Do you know if race pace will be selling these offshelf?
With a GTR, it's more like 10,000 things!
Yeah yours look as responsive as, wouldn't mind having a ride in it.
I'm curious on -9s being bit laggier than -7 from my exprience, it's the other way. But I'm comparing 302rwkw GT-SS to 270rwkw R34 N1 with EBC, but I'm comparing apple with orange here.
All I know so far is they are 4 GT2860's made into 2.
Given Garrett don't sell the wheels separate to the cartridge for that series... So it gets very expensive quite quickly.
When I find out more I'll update.
Garrett don't sell separate but you can get individual parts for Garrett turbos elsewhere.
SimonR32 would be interested to see your old T04Z graph I know it is a twins thread but just for comparisons sake as you had it pretty sussed out. Or maybe the thread should stay on topic a bit longer :)
Similar to the 517z's up to about 120 then ramps hard and monsters everything... But yes stick to low mounts for now :)
I discounted this because it had the better motor, but still same turbos :)
Really the major difference between the 2 is the amount of boost they are running.
Either way - they were both good track set-ups thats for sure. For everything else I'd prefer Ash's one.
  • 1 year later...
Apologies for the MAJOR thread revival, but I don't think anything else has been mentioned about these Racepace Hybrid turbos on this forum according to what my search results are showing.
Was the EBC eventually installed to see if there was any difference? (especially after the boost curve of this setup crosses over with the -7 setup, if it were able to at least maintain 19psi like the -7, that would be interesting to see)
Was there any further development into this setup?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
