GDay
Im in the US at the moment and wanted to bring over a TT setup from GTM. After discussing with a guy who did this to his 370z, he advised not to do it, due to refabrication of pipes (a lot of work)
Ive heard that the g35s, 37s, have the same block as the R35 gtr, but with less displacement. So their internally strong. Probably why they are pushing out unreal HP with these TT kits on low boost with stock internals.
My question is can we use parts that come off the R35 such as the turbos, intercooler, piping etc?? There are so many ownes now pulling these things off in Aus, so wondering if any of us can utilise them.
https://www.sau.com.au/forums/topic/350490-r35-parts-and-the-vq37vhr/
Get me two!
And no, they are not internally strong as far as FI goes. You won't be making 700hp like a GTR.
Its a great NA motor, not a FI motor. But they can be made into one with a big wallet
What have you been smoking?
believe it or not Im not the only one on the planet that thought they had similarities.
Thread below ansers eveything and with plenty of pics and detail.
http://www.ourvq.com/index.php?/topic/3117-does-the-r35-gtr-turbo-manifold-fit-on-a-vq37/
Get me two!
There strong enough when FI'ed. I cant be bothered to find out what 600rwHp is at the fly, but thats with stock internals. Im after around 450 - would like to keep stock exhaust and use the smallest turbos possible. According to that thread, the car still feels stock??? So it aint a pig. I'll be visting GTM within the 3 motnhs that Im over here to see if they do something for RHD.
Have a read of this thread below.
http://myg37.com/forums/engine-drivetrain-and-forced-induction/195180-gt-motorsports-gtm-stage-2-tt-g37-coupe-gtm-3-cat-back-gtm-flash-611rwhp-47-a.html
450 is attainable. But I doubt you would still be able to use the stock exhaust. Its all about how long you want the motor to last.
Have you considered Supercharging? HERE is a link to a Stillen supercharger for G37/370Z - 515hp at fly, 438hp at wheels - according to them.
Whatever you consider, turbo or otherwise, make sure it will fit 1) a auto car (guessing yours is), and 2) a RHD car 3) fuel that is available in Aust.
Other than that- go nuts :thumbsup:
Oh, and if its an auto, you'll need some work to the box to take the torque.
Wanting to keep the stock exhaust so it stays quite. My last wrx would literally shake the walls of our unit. Was never popular with my neighbours.
Ive always had turboed cars, celica gt4, soarer TT, R33 gtst, wrx, so Im biased towards turbo's, but I did have a look into the Stillen supercharger.
There's also a reason why the VQ35 motor has earned the title "glass bottom end" when it comes to FI. Tougher conrods are a must if you want any longevity.
wasn't aware of that. I went into a 350z site and had a little bit of a read and it didnt look like many of them were upgrading the rods?
They won't be making good power on the stock rods. It is a fairly cheap exercise for them as a set of Eagle rods starts at only $500, I don't know why they wouldn't upgrade.
^ Lucky Stagea drivers do... don't know what that makes me...:wacko:
Anyway, I just thought so should look into Supercharging a bit more, if you want to keep the stock exhaust. I think it would be tough to keep a stock one and still twin turbo it. That being said, what you are really after is not necessarily a stock exhaust, but one that doesn't produce more db than a stock.
I understand because atm I have a Honda tuning place up the valley from me... and I can hear the same car on the dyno for about 30mins now....:rant:
Mate I feel sorry for you......probably got a big ass canon and getting tuned for an extra 3kw.
Your right, I can do with an aftermarket exhaust, just as long as its not loud.
There are a lot (hell of a lot) of g35s and g37s here. Also the M series. Most are driven by families and I get no feeling of 'whoa a g' over here. Just Nissans version of the Camry or Commodore. But they are still a great car, even though they are common.
Those TT cars from GTM are suffering from heating issues. They cant seem to run for very long without high oil/ engine temps. Revzone in Melb has put one of these kits on a 370z. Its running some crazy numbers.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
