Wondering about how many Ks what went wrong for those of you who have been unlucky enough for one of the above or something else to go bust on you, would be interesting to see if this is a age of the part or an amount of use "ks" related thing. As my car has somewhat higher ks than other V35s out there yet im only starting to have issues now
The reason Im asking is because my car now has 84k, I purchased it with 50k. Up until a couple of weeks ago I had never had a problem with the car until the drivers side window motor decided to give up
Sure enough as some of you may have read I ended up fixing the problem by cleaning the motor and putting everything back together
Now the last couple of days I have noticed that my drivers side door has not been locking/unlocking all the time when using the remote on the key
I pulled the door apart again today to see if any of the lock cables had come undone but everything was in its place
Iv read up on the net and again like the window this seems to be yet another common problem for G35/V35s
https://www.sau.com.au/forums/topic/350565-ks-on-cars-when-things-break/
i cant remeber k's when i bought my car, have to check the books, but now with 58000kms window for ps went out, getting it replaced with a brand new oem that i have coming in this week, just waiting for call to book and appointment to get it pro done. im selling the car so i dont want any complaints or faults from it when a person comes to inspect it...which so far has been no one lol.
Edited by ezy03
I bought mine at 76,000kms in 2008, and it's sitting at 89,000kms now.
Problems are:
1. Window motors gave up around 80,000kms (1st was the driver side, a month later was the passenger side).
2. CD player (OEM) makes abit of stop-start when playing music in the first minute or so, and then it's fine afterwards.
3. Fuel gauge needle doesn't go all the way up anymore after filling up full-tank around 80,000kms.
4. Tiny bit of rattling noise when going up driveways lately.
That's about it. Otherwise, it's fine. :)
Edited by Victor.T
Our 2003 V35 Sedan (65000km's) hasn't had any issues yet. The only thing I hate about it is the fuel gauge. As soon as it hits 1/4 it shoots down like tomorrow. I was panicking one day as I visited a mate (Yin Sun on here) as the wife and I left the fuel gauge was on a 1/4 as we went around the corner it shot straight down and the fuel light came on. I crawled it around the block to the nearest servo and I was pulling in the fuel gauge went back up to just under 1/4! I put some fuel in it anyway and asked the wife (she drives it the most) as soon as it hits on or near 1/4 fill the bitch up! But other than that it has been fine.
Edited by omp
At about 78,000 kms my driver's side power window was playing up. I Took the door trim off and pressed the reset button. This fixed it. Now it has 80,000 and so far so good.
Yeah, driver's side window not working is more painful to live with. I used to park at multi-level car parks before I put on my kit. When the driver's side window didn't work, I had to open the door to get the ticket in and out.
Quite embarrassing when you go on cruises with friends. :P
Edited by Victor.T
OH yeah where is the reset button located???
my Drivers side went completely and replaced it.
now the passenger side has started playing up
Cheers
Mine's at 92,000k's and my passenger seat won't slide forward when you get into the back.
Stopped working at around 89,000k's, Other than that, everything else is fine.
So, how do you deal with that issue, Bee? Can you still push the seat forward?
I can still use the button, just wont do it automatically.
Doesn't bother me as i hardly has people in the back seat,
Will eventually get bride seats later on in the year.
Iv been wanting to get a bride or similar seat for my car but the whole airbag thing kind of put me off it. Whats the deal with the airbags when you pull out stock seats?
car is currently sitting on 76kays
couple of months back the window failed to go back up after opening the driver side door...realised coz there was wind noise when driving...only happened the once tho so knock on wood.
single click on rear axle when going to D from R, heard its a common problem but requires rear driveshaft to be removed, greased and rotated...cbf coz i'm not really a DIY person
other than that it drives superb
with 'creativity ' its doable.
though pulling the stock seat out tends to piss off the SRS unit.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
