Hi guys,
I live in Sydney & want to know if anyone knows of who can remove my front & rear window from my r32gtr shell?
I guess i could call o’brien glass – is there anyone else though as im sure they wont be cheap...
Alternatively – i am tempted to do this myself as well if anyone can point me in the right direction.
regards
https://www.sau.com.au/forums/topic/350820-any-window-removers-in-sydney/
stevo - the thread you closed was directed at 'can i remove the windows myself' whereas this thread is 'who in sydney can remove my windows'...although i do also ask in this thread whether i give it a crack myself - nonetheless i understand the confusion :)
back on topic
I have removed a rear before , i used this tool
I got it from a windcreen supply warehouse for about 35$.its basically just a handle with a bent blade on it and another handle to help you drag it along, you could make one if your clever enough..
Im not sure if windscreen places like obriens would sell them but if you find the people that supply there windscreens they should have them..
Its a prick of a job but if you keep the blade clean and sharp it csan be done with patience
There is a wire that runs around the rubber and apparently if you hook it up to a battery and heat it it soften the rubber, though i have never tried this way the wire does exsist good luck finding the ends though..
But basically you just have to be really gentle and cut your way through the rubber ,i think I did use a hairdryer to soften it a bit as well. Heat, slice, heat, slice And make sure you dont twist the screen by pulling on one corner or something you have to keep it flat,lay down in the car and push it with your feet gently if you can once the rubber is cut away..It will test your patience..GL..
Edited by Arthur T3
i got a quote for $90 to get the rear window which is toughened so the glass expert said this wont crack, however, as the front windscreen is laminated there is a 50% chance of it cracking which sux
if they cant get the front out every time without fail they should give up and look for another job
I'm thinking that this is a bit of a tough call... a glass company can't really say for certain the strength of of the forward facing window of a 20 odd year old vehicle which probably has seen it's far share of stones and other crap thrown at it.
I replaced the rear window on my old R31 once, granted it was already shattered so the removal process was simply to break the glass further and clean the area around the window so we could stick the replacement in... tools used where a hammer, a chisel and a screwdriver :)
if the window is in good nick there shouldn't be a problem getting it out with out cracking it
i dont give a shit about excuses, if you're a window guy thats your job and if you can pull a front screen without breaking it you need to find a new job
im sick and tired of the "all care but no responsibility" bullshit they all try and spin
i had an absolute dead shit from obriens smash both my rear quarter windows on my skyline the first time i painted it
so thats $550 each window plus the money he wanted to pull em out
i told him where he could stick his money cause he didnt do the job so i wasnt paying him
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
