Hi Guys,
I have a quick question about the EPA.
I have had two FULL EPA's in the past. One was in May and the other in September of last year. On both occasions I was pulled over by cops and defected on the spot and had the EPA notice(s) sent approx a month after the defects.
I then was told that if i get another EPA I would get a large fine. Does anybody know the cost of this fine and if this is true?
And if I was to receive a simple noise test notice in the mail would that still count towards the 3rd strike or does it need to be a full EPA for me to get this 'fine'?
I have checked the EPA sticky and read through quite a bit of it but couldn't find clarification on this.
Cheers
https://www.sau.com.au/forums/topic/351002-query-about-epa/
EPA notice is an EPA notice, even if it's just sound. If there is some sort of 3 strikes scheme then you can be sure you'll cop it. If they find you a large sum of money, it's because you're not "learning your lesson" and it's probably time to consider ditching the mods or the car?
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5632645
whether you think so or not... i can tell you as fact, there is
if you don't believe me, call the EPA yourselves :)
there are a number of users who have posted up of late that have been EPA'd with around a 500 fine.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633278
yeh the fine your talking about nismoid is the $600 one for exhaust noise been over which the people who copped that have been done at EPA random test sites etc, dont think you can get the find when you have been "dobbed in" so to speak as there is no proof your car is/was over the DB limit at that point in time.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633357
There is certainly a 3-strike type of thing as well.
I remember discussing this with Lou Raffa moons ago. He is the guy who does most of the inspections, you can contact him if you ring the EPA and ask to talk to someone about car related EPA notices etc.
I don’t agree or think it’s right – but they assume that if you keep getting reported, then you keep illegally modding the car after you get tested. Anyone who voted for Bracks should hang their head in shame.
  • Like 1
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633385
EPA & Fines = becoming more regular.
There can be a fine associated, rest assured it does exist, of that I am 100% certain.
Yep! I've only had one EPA for noise and they mentioned they weren't giving me a fine but the fine for a noise EPA notice is $599...
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633648
Thanks for the feedback and help guys :)
I guess my next question is - My 2 past EPA's were full ones (Noise/ Emissions + visual inspection under hood etc) so they weren't just noise ones. If I get done for another full EPA (not a noise one) will the fine be more severe then the $599 fine as mentioned in this thread?
Cheers
Brent
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5634217
YES you can get a '3rd strike fine'. My mate copped 3 EPAs (none for noise) and yes on the 3rd one he was going to have to pay a ~$600 fine if he was to clear it.
From what I remember the fine was not actually for not complying with emissions; it was a fine for putting stock stuff back on and trying to 'trick' the EPA upon inspection, despite the fact they had photo evidence of the highmount GT30 and External Gate not plumbed in :)
The car is no longer street registered.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5638637
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
