Hi Guys,
I have a quick question about the EPA.
I have had two FULL EPA's in the past. One was in May and the other in September of last year. On both occasions I was pulled over by cops and defected on the spot and had the EPA notice(s) sent approx a month after the defects.
I then was told that if i get another EPA I would get a large fine. Does anybody know the cost of this fine and if this is true?
And if I was to receive a simple noise test notice in the mail would that still count towards the 3rd strike or does it need to be a full EPA for me to get this 'fine'?
I have checked the EPA sticky and read through quite a bit of it but couldn't find clarification on this.
Cheers
https://www.sau.com.au/forums/topic/351002-query-about-epa/
EPA notice is an EPA notice, even if it's just sound. If there is some sort of 3 strikes scheme then you can be sure you'll cop it. If they find you a large sum of money, it's because you're not "learning your lesson" and it's probably time to consider ditching the mods or the car?
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5632645
whether you think so or not... i can tell you as fact, there is
if you don't believe me, call the EPA yourselves :)
there are a number of users who have posted up of late that have been EPA'd with around a 500 fine.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633278
yeh the fine your talking about nismoid is the $600 one for exhaust noise been over which the people who copped that have been done at EPA random test sites etc, dont think you can get the find when you have been "dobbed in" so to speak as there is no proof your car is/was over the DB limit at that point in time.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633357
There is certainly a 3-strike type of thing as well.
I remember discussing this with Lou Raffa moons ago. He is the guy who does most of the inspections, you can contact him if you ring the EPA and ask to talk to someone about car related EPA notices etc.
I don’t agree or think it’s right – but they assume that if you keep getting reported, then you keep illegally modding the car after you get tested. Anyone who voted for Bracks should hang their head in shame.
  • Like 1
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633385
EPA & Fines = becoming more regular.
There can be a fine associated, rest assured it does exist, of that I am 100% certain.
Yep! I've only had one EPA for noise and they mentioned they weren't giving me a fine but the fine for a noise EPA notice is $599...
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5633648
Thanks for the feedback and help guys :)
I guess my next question is - My 2 past EPA's were full ones (Noise/ Emissions + visual inspection under hood etc) so they weren't just noise ones. If I get done for another full EPA (not a noise one) will the fine be more severe then the $599 fine as mentioned in this thread?
Cheers
Brent
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5634217
YES you can get a '3rd strike fine'. My mate copped 3 EPAs (none for noise) and yes on the 3rd one he was going to have to pay a ~$600 fine if he was to clear it.
From what I remember the fine was not actually for not complying with emissions; it was a fine for putting stock stuff back on and trying to 'trick' the EPA upon inspection, despite the fact they had photo evidence of the highmount GT30 and External Gate not plumbed in :)
The car is no longer street registered.
https://www.sau.com.au/forums/topic/351002-query-about-epa/#findComment-5638637
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
