Aight this is hoefully the final version of me and my boot tails, Basically one day i decided that im going to do an overhaul of my car, and clean it out from head to toe, as i doubt its been washed in about 12 years..
So as i set about doing this i noticed a few bits and pieces and was interested in knowing what exactly they do, and what they are! ..
Well considering i dont have a workshop manual, dont have a wiring diagram ..and not knowing anyone with an r32 .. ive turned to you guys for help, and hopefully others can learn from these investigations too
Exhibit A
1 - This is the box that activates the word "Skyline" inbetween your tail lights when your lights are turned on *Note: Not all skylines have this-
2 - Bracket That Holds your Jack
3 - The box for your Antenna
Exhibit B
1 - This is a hatch to your fuel tank
2 - This is the wiring that sends a fuel reading to your "Fuel Guage" on your dash (tells how much petrol is in the car)
3 - *** Unsure what this is but those wires lead to a box mounted on the otherside of the wall ***
Exhibit C
1 - Power Amplifer for the Car Speakers
2 - *** Unsure ***
3 - Right hand speaker that is mounted in your rear parcel tray
Ther Following photos are of "Exhibit C" .. please let me know if you know what they are?
? - Power Ampliifer for Car Speakers
X - I think this is the unit that controls the rear wiper
Z - Wiring that has been cut, anyone know what this is from/to?
Thanks for youe help, and please let me know if any information is incorrect
https://www.sau.com.au/forums/topic/35180-fluxz-boot-final-version/
Amplifier is stock. Everything else is correct as well.
The extra wiring loom i would have a clue, but it looks like all the wires are cut going to it anyway. Perhaps the remnants of a sound system - cd stacker maybe?
Your car is the first r32 that i have seen that has a non-rusty plate thing near the fuel pump wiring. Or whatever that thing is in pic 2 under the number 2 item on the boot floor.
I looked at probably 8 r32s when looking for my car and all of them had this item rusty.
Heres somethign interesting.. i took a closer look at the small bunch of wires (Exhibit Z) and it appears most of the wires are cut except about two which lead to the second bunch of wires..
it looks like the white plug in Exhibit Z is ment to connect into the Power Amplifer.. but its not connected..
wonder why?, any idea?
Edit: is the power amplifer for the car speakers? or for the cars electonics?
Omg, that was like 10 times harder then a thaught just to get some damn night shots of my tail lights..
well after all that hardwork, it just wouldnt happen, just wouldnt come out clear for some reason.. this is the best i could come up with
actually i just took a second look, the pictures arnt even worth posting.. someone with a good digi cam will be able to get a shot off next week.,..
sorry
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
