Hey guys,
Selling a lot of parts off my GTR due to going single T04Z turbo and upgrading most other parts.
Used but in excellent condition Blitz Pod Filters and pipes to suit GTR - $150
R34 GTR Turbos Rebuilt with steel exhaust wheels under 15,000kms ago. Minimal shaft play and in excellent condition. Cost $2500 when purchased (have receipt to prove) - $800
New Tomei Poncams Type B - $650
GTR BOVs in good condition. Comes with piping brackets,etc.. - $110
R32 GTR intercooler in excellent condition. No dents kinks, etc... - $120
Twin turbo piping, intercooler piping, standard dump pipes, front pipe, etc... - $offers?
5 factory forged R32 GTR rims with tyres. 4 rims are wrapped with Kumho KU36 tyres which have 80-90% tread left. The spare is wrapped in Bridgestone GIII with 70% tread. The rims are in really good condition. The spare has some light rash but the others are fine.
Rim specs are 16" x 8" +30 and tyres are all 225/50/16.
Looking for $800ono for the 5 rims and tyres. Not bad value considering I paid just under $1000 for the 4 KU36 tyres alone.
Complete front and rear brake setup out of my R32 GTR. Included is 4 brake calipers 70k kms old, 2 front drilled rotors, 2 slotted rear rotors and a set of brake pads to suit with plenty of meat left.
Looking for $500ono.
Standard Coilpacks off R32 GTR that;s done a genuine 70,000kms. Excellent condition. Never missed a beat. $50ono
Cobalt Air/Fuel Ratio meter. $40
Standard Air flow meters off R32 GTR. The joints have been re soldered recently by my cousin who is an electrician - $50
Exhaust manifold with heat shields - $100 ono
R32 GTR custom oil cooler kit. This was a custom made kit made by Tenegah. The oil cooler sits in front of the subframe and has an under tray with scoop that draws air to the oil cooler. It also comes with a Greddy oil filter relocater. It comes with everything required to fit. - $300
Located in Perth but can post at buyer's expense.
PM or contact 0402870429 if interested
Thanks
Edited by Chris32R
Could you please give me more info re the turbos?
Who rebuilt them and with what?
Were they hiflowed or anything?
Are they still ball bearing?
Have you got any dyno graphs so I can see how they went?
Tried to PM
Does the oil cooler come with a thermostat?
Yes it does.
poncams to suit 32 gtr?
Yep, To suit R32 and R33 GTR.
Turbos are on hold atm.
I'm going through messages now.
If you have any questions, please call, SMS or post in this thread because my PM isn't working for some reason.
Thanks
Edited by Chris32R
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
