^ would have loved to see his eyes in the shot tho, even if its just one eye. But otherwise I like the mood tho. Good work.
Yeah, would have been good to get eyes in at least some of the shots, will try again later, may pick up a difuser to give a bit more light in to the dart side of the face and the trumpet
Hahaha thanks for the comments. I imagine this thread in a years time will be crammed full of all of us pro 'togs hahahaha.
After i get back from Japan Sidd. Although i want to pour money into the evo haha. But really thinking about it now, if i invested in a rig, i could probably make money from taking photos. Interesting synopsis.
Have to do a proper session with the chaser after i get back from Japan.
When you getting the tune done?
When you going to japan again? Sorry I keep asking you, but I keep forgetting hahah.
Hopefully get tune done end of feb or when I come back from overseas. Got a wedding in march so might do it after then. Wish I had money for hi-flow turbo tho.. sigh
Sidd, good choice with taking it to Yavuz - he is a legend. So down to earth, yet so knowledgeable. He takes the time to listen to you, answer questions, explain everything so you understand, and his work is good value too!
Let us know when you're heading out there for the tune, I live less than 10mins away, and Matt works about 10mins away too.
sure. the more dicks the merrier.
nice shots serg. i like how you change up the angles and locations. i wish our local had as much potential for locations and angles. Maybe i need some cammo so i can get up the track itself ;) haha
