  • 4 weeks later...
That dash wouldn't be hard to replicate poit. I personally wouldn't give up my factory dash for that, but that's me. To make that in 1-1.6 mm ally sheet would be fairly easy, weekend job tops. Looks to be just satin black, few hole saw bits to match ur gauge sizes etc. looks NASCAR spec
Edited by Mr. Untouchable
yeah I think I should just tidy up my stock dash and leave it, take the heater core and AC out too, seeing as they're not hooked up...
I need to make some door cards more than anything!
Edited by zoidbergmerc
  • 3 weeks later...
I've been fooling around with the 33 and took some pics to share.
So I thought I had a pretty major problem when at symmons plains I was getting some SERIOUSLY bad vibe through the wheel\car when going faster than 90kph. I was like the f**k my car is going to fall apart.
I was pretty convinced that something was seriously a miss with the passenger side front suspension\bearings, something was not right. I pulled it all down and low to behold, it was all brand new, it wasn't till I was putting the wheel back on that I discovered the massive flat spot on the tyre -_- FAIL
Then I painted and fitted my new wheels, they're Rays SS7 18x9.5 +38 but to get them to fit I had to install a 15mm bolt on spacer as they fouled on the upper wishbone(?) when on full lock now it clears by about 1mm. They were gold but now they're Matte black, and I'm thinking of painting the lip red to match my lensos and break it up a little. The tyres are Dunlop D03Gs in a medium Compound, 245\40\18 for the front and 265\35\18 on the back.
I'm pretty sad about my Drift Teks getting so f**ked up after my little spill at Symmons :( Those rocks hurt!!
I also put in a passenger seat for the Charity Rides day in a few weeks :)
I also fitted some new brake pads, Hawk DTC-60 should pull the while whale up nicely :)
Hey Pete if you didn't already know its really easy to add a stripe to the wheels. You can either buy some red pin stripe or cut a pice out of vynal. It can just be a strait pice. As you put it on the wheel it will flex as such and turn a strait line into a curved line. So no need to paint it or cut out round stripes. I have done this neumerous times to wheels on a race car I used to look after.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
