  • 3 weeks later...
Hey yeah, I got all my bits OK :) A bit delayed because of bushfires, but they're all good thanks!
RB25 to go in the 33 is good to go now, putting that in on Monday.
RB25\30, progress is good, gotta save up for the machine shop work, then just re assemble it with some new bearings and new rings.
RB30e got yanked out Monday night, it got dark before I could rip the sump off and change the oil pump gasket and sump gasket. I might do that on Thursday afternoon.
Mega Super ultra powerful monster RB25 is still in the research and development phase at the moment, but I'm thinking. JE pistons with ceramic tops and teflon skirts, Nitto rods, balanced crank, nitto collar, ACL bearings, 12mm head studs, Bore and Deck block to suit, Grout filled block, all them oil control mods, Aiming for around 9.8:1 Static CR, still not decided on that really, NEO head some crazy cams and springs, yet to be decided. Not sure what turbo either, Looking for around 450kw though running on E85
I'm really undecided about the whole mega RB25, Lots of people say different things about what's needed for big power, like RIPS motors are like, near stock and good for like 500hp, and their built ones are insanely powerful. Put you look at everyone in the 400kw club here on SAU and they've got lots of mods.
First TSS round is in Mid March, I might go out to a drift practice day to shake the car down though, or maybe sprints, depends on how I go for time and what's on when I suppose.
In a RWD platform you'd be crazy not to put a rb30 in. Extra torque for no extra cost in the build.
Just keep in mind that RIPS build and TUNE the motors that produce massive power. Although stock can produce great numbers, it's usually the oil issues that kill them.
Id only use a neo head if you were retaining VCT. Even then the available upgrade parts aren't as good and a 26 head would be easier.
RB26 doesn't have vct, it also means he'd have to bin the exhaust manifold as well as the intake, neo and 26 have solids but the neo has larger ports standard, neo head studs are the same size as a 30 bottom (RB26 are larger), you can get neo heads cheaper, easier and usually in better condition.
Its a pretty obvious choice, the only thing it doesn't get you is "RB26/30" as its name, which loses value regardless of performance :P.
Edited by SKiT_R31
Oh, it doesn't? Thanks for clearing that up. Mine does.
His intake won't fit either way. Head stud size doesn't matter.
Ports aren't bigger, they are shaped differently to previous 25's.
bigger is not always better when it comes to these heads.
The solid lifters are also not the same setup as rb26, with a shim on top of bucket.
He was talking about modifying cams etc. so the head wouldn't be taken off a wrecker motor and put on without first being checked. Then start getting upgrade parts for them....
Edited by jangles
Any RB head can run VCT, but 20's and 26's need the head modified to make it work.
Janges is right, bigger is not always better on the intake size. The correct size is always better.
Any reason you want to run a solid head? Brad has been reliably running 1000hp on a hydro head.
Is it still a hydro head though?
Neo heads will spit shims in high rpm and kw applications.
Yeah I've been lead to believe that brads new motor has a neo head. And shimless buckets.
There is no doubt a 26 can have vct, but I'm not interested in doing the required modifications when just slapping on a neo head is a Shit tonne easier. Also neo heads have a smaller combustion chamber which will give me my desired compression ratio with my current pistons.
Plus they're cheaper.
standard maybe, you were talking about cams and all sorts before though on a super build.
Edited by jangles
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
