Hi All
Looking to get some exhaust work done to my R34 N/A
I'm leaning towards a Varex twin tip cat back,
has anyone got this system set up & if you do what do you rate it?
Is it loud when open, is it stock quiet when closed?
What's the price for something like this? etc...
Thanks.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/
Hi All
Thanks.
About 2 years ago I had a 3" turbo back exhaust put on my GTT and decided to go with a 3" twin tip varex. In my opinion they are bloody brilliant. It is loud when open but not LOUD LOUD as you'd get from a cannon or so on. When closed it is definitely as quiet as stock.
However...... bear in mind, your car is N/A. You don't have a turbo, which acts as a muffler in itself. So if you run the varex on its own it would definitely be louder and maybe drone more than on a GTT. You may need a mid muffler somewhere along the exhaust and then have the varex on the end. Hopefully there is someone here who is running one on an N/A who can correct me... or confirm it.
But yes, the actual varex unit itself is great and still works perfectly for me 2 years on. Good quality. The remotes are a little fragile so if you decide to get one, take care of them. From memory the muffler set me back $400 or so. Might be a tad cheaper now? The only downside I can think of is if you drive around with it open the whole time, only the right tip will get carbon build up on it and will look darker (only on the inside, outside is still bright chrome). So you kind of need to run it shut for a while too so the left tip can build up and match the colour..
I have ordered a camera mount of eBay and when it arrives I am planning on recording a video of driving with it open / closed.
Edited by R34mac
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5655579
hey mate
ive got the exact system you're after haha
2.5inch cat back
8"x4" centre mufler (its the biggest they could fit)
twin tip varex.
it's awesome dude, when its open it sounds sweet, its loud but not so loud that you're going to be heard 10 blocks away and when it's closed it's dead silent :)
don't make the mistake i did and not get a centre muffler, it was the most disgustingly loud exhaust, not to mention it sounded like absolute sh*t haha
if you go somewhere and they tell you there is "not enough room for a centre muffler, only a hot dog" go somewhere else, coz there definately is !
mines made of mild steel and is mandrel bent (press bent is sh*thouse) and cost me 1200 all up including wiring of the varex.
hope that helps pal
ps. in regards to what r34mac said about the right tip getting more build up of crap, this was true on the older versions where the valve was situated behind the right tip, now its smack bang in the middle so don't have to worry about this problem, also the remotes are a bit better than they used to be too :)
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5655892
hey mate
2.5inch cat back
twin tip varex.
hope that helps pal
Thanks for that guy's your info came in handy,
I'm convinced that I'll get the Varex muffler now it sounds like a pretty good quality system for your money.
sounds like a centre muffler is mandatory though for an N/A.
Anyone got an idea where you can buy these muffler's other then ebay?
Cheers.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5656144
i got mine through the guy who did the system for me, pretty much go to any exhaust or auto shop that deals in xforce and they will be able to get it for you.
don't buy off ebay because then you're not covered by warranty in case something should go wrong !
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5656488
I'm running a single 3" cannon on my R33, sounds great when open and quieter than stock exhaust when closed. However in terms of power you lose heaps when running it closed and try and put your foot down.
The whole catback system I paid $650 for installed, I think the tip alone is around $300-350 ish...
As stated anyone who deals with Xforce can get these in for you.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5686908
See my quote fron another thread
Not trying to start a fight here.
But Varex mufflers are the most expensive POS ever...actually same can be said for ANY X-force product.
A real muffler and not some made in china pos with a flappy valve thing would have sounded so much better without the need for a centre muffler.
Things like Remus/Borla/Hooker/Magnaflow etc are properly designed to flow and quieten rather than just be a tin can with some perforated tube badly welded in the centre.
So while some of those brands are expensive (the hooker aerochamber is only $100 bucks) would be cheper than the Varex and would have saved you needing to buy a 2nd muffler.
Not bagging you car at all just a tip for young players.
Also note the Varex/other flappy exhaust things are illegal as it wasnt fitted OEM
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5687216
Have you had a Varex before Zebra? 18 months and still running great in my car, still sounds as good as the HKS muffler I had before...no power loss. Given the twin tip Varex is actually just a straight pipe when it's open, more important is how the rest of the exhaust system is setup IMO. X-force are the last company I would associate with expensive though...bar Varex which is a unique product, their stuff is some of the cheapest you can get off the shelf.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5687307
I personally havent had a varex muffler...i simply refuse to use any X-force products anymore, they are cheap for a reason.
2 mates have have 2 1/2" dual X-faorce exhausts on V8 commodores, the mufflers fell to bits within 6 months, another mate had a dual stainless 3" exhaist on his VT2 GTS and the welds broke/cracked in two spots.
I had an X-force 3" dump on my 33 and had to modify it to fit because none of the flanges lined up and it leaked so I had to re-weld the cat flange.
So maybe the Varex is ok (it would want to be for the price) but give it another 18 months and see how the little servo goes with the heat and grime etc.
If it lasts well thats good, but I will not use one, I would still rather a propper exhaust rather than relying on a flappy valve thing.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5687331
Get what you pay for I guess, the same goes with the JustJap dump pipes and the ones on eBay. None of them ever line up perfectly and almost always require modification. That said, I have an X-force high flow cat too and that's been fine. I hardly use the valve anyway, I bought the muffler mainly because it's one of the few mufflers on the market that looks like a better looking version of the standard twin tip exhaust muffler, therefore more cop friendly even if you don't use the valve.
Again this was the twin tip design, the single cannons are different and I would not use one personally, but I did like the redirection design that the twin tip uses (straight exhaust out one tip, redirected through the other tip) and it truly is the quieter than stock with the valve shut...which no aftermarket muffler will give you the choice of having. And that's what it comes down to, that no matter how shit a Varex is (and it isn't IMO), it's still the only one of it's kind out there - we won't even bring up the Apexi valve lol.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5687474
Twin tip it, 90% of cannons are done disgracefully. Subtle twins always look good. If I had a free kill it would be the the first motherf**ker who ever put an unnecessarily large exhaust pipe on his car and started that bullshit trend.
https://www.sau.com.au/forums/topic/352800-varex-exhaust/#findComment-5688037
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
