One Tomei 2.8L crank ready for balance
Was 1g out on balancer end and 0.6g out on flywheel end .... Usually a green light in most places :)
Not good enough for the master.... Finely balanced till there is 0 grams variance on both ends :P ......... This can take many hours lol
Quaife diff ...best on the market hands down.
They do read up pretty good! i have never driven a gtr with a aftermarket front diff. Cant wait! :)
Although, i did spend some time this week having a good chat to BOBBY/JEM about his build and he has definately given me some food for thought..... :blink:
1. I should avoid aftermarket front diffs as they have the potential to crack the block! (i have cracked a block in the past and it had a standard front diff) Can anybody add to this from personal experiences?
2. Cam choice... i am in fact running the same camshafts as Bobby but in opposite form i.e 260in and 270ex Tomei 10.25 lift .... i had noticed this staggered option to be quite the norm in many applications.... Obvisouly with the extensive lengths that Bobs and Skola have gone to run the opposite combo.... what would be the pros and cons of such choices?
3. Static compression and squish.... i am also aiming for a 10:1 comp ratio and had worked out the the squish would come to about 34thou.... Bobs mentioned it was imperative that it is 33thou squish otherwise the motor wont be able to run timing and detnonate........ also how much can you skim off the head and what are the downpoints of taking too much off?
To be honest, its all a bit too much to absorb :(
Hey Steve,
It was great chatting to you giving you the info, anytime mate more then happy to help.
Just wanted to clear one factor to control squish - is by decking the block or using the correct head gasket to achieve 33 thou - decking the head will not change squish.
Hey Steve,
Hey Bobs!
decking of head is more to acheive disired comp ratio..... what is your opinion on this? can you take off too much? Also can i get the details of the machinist that has the template to do the water gallery mod. Cant really find the exact details in your epic thread lol. Also what else are you doing for cooling with respect to water for your car. Are you running a water/air breather tank? Restricting water going back into the radiator at all?
:cheers:
the quench distance is measured from the face of the head where the squish pad actually is to the top of the piston at TDC, skimming the head doesnt change that distance, a thinner or thicker headgasket will change the distance between the quench pad and piston which will yield a different 'quench distance'
other things that will change the squish is machining the block face and or machining top of the piston by a few thou - i dare say that if you do decide to shave some material off the pistons it may have adverse affects on the piston if too much is taken off
Bobby can you explain how decking the head will not decrease the quench distance?
I would be interested to see how much timing and boost can be put in at 10:1 static comp.
Snozzle has answered it perfectly
Well i dont see anything wrong with running normal timing for a good engine!! you just have to get the squish right as it helps eliminate detonation and this is why you can run more timing and still have high comp.
Hey Bobs!
:cheers:
What ever comp you are aiming for you will have to adjust your cc in the head or deck the head, this depends on how much you are decking also as there is a limit when your valve will get too close to the piston.
The machinist is Wilkins performance 9674 7037 tell him you need the head drilled to eliminate air locks. Mention my name and john skola he will remember.Yes i am running a ARC water bleeder tank you need this its very important. No not restricting water at all well im still waiting to buy a radiator as i need the motor in the car to check clearance as i will be using thermo fans.
Also the best way to measure your squish is by putting a dummy build together with a used head gasket. Place thin lead wire where the squish pads are on the piston and turn the motor once and measure the thickness. from this you can calculate if you need to deck the block or use a thinner gasket.
I hope this info helps
Wow that is a blonde moment if I ever had one, embarrassing... thanks mate :)
1mm gaskets and piston sitting above 0.0064" = 0.033" squish
minimum factory recommended valve clearance is 0.080" I've taken 0.090" off my 26 head to get to 10.75:1 and i still have 0.130" intake and 0.180" exhaust piston to valve clearance with a 10cc domed piston
I will check piston to valve clearance before i grind the head
Champion !!
i will call you when i get a chance!!
:cheers:
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
