would include chrome.. chrome and well some chrome.. did i mention some chrome?
generally ricer bays are regarded as the ones with the painted engine. chrome everything.. wires all hidden.. everythings done for show
Since when is having a nicely detailed engine bay a bad thing?
Fair enough you can go a bit overboard with chrome, but even then it can still look very nice. Dahtone's engine bay comes to mind in looking incredible with a lot of polished parts.
Lol about a TV screen though.
Don't think it's a bad thing.. I think there are the 'sleeper' guys who go for the "what mods does it have officer.. it's just stock" look.. Dahtone was gonna be my example.. Looks great..
+1 thats me..
althought i've been pulled over once 'randomly'.. its a wagon FFS
Ricer, by definition of the typical owner, requires the vehicle be fitted with:
-Pod filter, not mounted or enclosed
-Fluro green ICE 16mm ignition leads, stock coil lead
-Anodised oil filler cap
-At least 2 cable ties without the ends cut-off
-At least 1 engine component that has been sprayed with trevs "metallic" paint without cleaning or removing said component from the engine bay
-Stickers on the radiator support to advertise said Anodised filler cap
Optional accessories:
-A bottle of "NOS" fuel additive kept in the engine bay for your next top-up
-Un-fused see-through-red 4ga wire running from the battery through a hole cut in the firewall with a butter-knife
dont forget.
a vacuum hose which is bright red leading through that same hole cut in the firewall to a boost gage. even though its an excel.
dont forget.
LOL, but even N/A's need their vacuum pressure monitoring right?
BTW I think you're lying and have never seen that. ;)
Pics or not true.
Pics or not true.
no lol this was me when i first got my NA supra at the age of 17.
i had to do something and it was the only thing i knew how to do..except i didnt know you could get a vacuum gage.
atleast im in admittace . and have grown up since then.
but since you asked..
breewwww
Edited by AaronNM35
not a ricer, but thats the only type of engine bay i can think of that looks daaamn clean
Not a big fan of 'dubber' engine bays. I mean they look good but it's all smoke and mirrors with the wires and everything tucked out of view. Actually working on the car and troubleshooting would be a bitch and so for me it's the ultimate 'show' look. Real cars otoh are made to be USED.
Clean and tidy engine bays isn't RICE.
To me, R.I.C.E. stands for Race Inspired Cosmetic Enhancements..
So things like, pod filters, big gay atmo bov's, coil covers with stupid logos/designs, painting everything up when it's all stock componentry etc.
I think R.I.C.E. is more generally found on the outside of a vehicle.. bigass wings, shopping lists, 6" cannons on 2" pipes, neons, graphics etc.
rice engine bay = you pop the bonnet and every single thing screams "look at me!!!" whether it is a performance mod or something normal made to look like it is a performance mod, such as an anodised oil filler cap. basically when standard items have been replaced with something brightly coloured for no apparent reason
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
