OK So First DECA for the year....March 19th
And as per usual no volunteers to help us for the day means we cannot run the day.
So we are calling for your assistance - if you're willing to help, or if you're bringing a friend/partner who's willing to help - please speak up.
We can explain what you need to do if you haven't done it before, so don't stress about that.
It is VERY easy stuff and you will get a great view of the action!!
(very good for you budding photographers)
All officials will be given a free lunch and water during the day.
We also need all officials to be at DECA by 8.00am on Saturday morning - same time as competitors.
We will be organizing Volunteers prior to the Drivers Briefing.
Until all slots are filled, Drivers briefing will NOT go ahead and the event will not start.
I know it sounds harsh but without these people we cannot run the event.
Please PM me if you are able to help out. Even if just for 1/2 a day.
Thanks Heaps
Martin
Morning
Long Wang
Starter - hayley
Finisher/Timer FEMINO
Flag point 1 -sanjay
Flag point 2 – ???????
Mini Wang
Starter - Anna
Finisher/Timer (2) - ?????????/
Skidpan
Timer jett
Hat Removalist - Juliette
starter - Wayne
Afternoon
Skidpan
Starter - Wayne
Timer 1 -???????
Timer 2 -???????
Time Recorder - ???????
Hat Removalist -???????
Look forward to seeing you all there an having a fun day.
https://www.sau.com.au/forums/topic/353404-deca-helpers/
  • Replies 51
I still reckon volunteers should receive priority entry into the next DECA if they wish. You'd probably get a lot of people who miss out instead come up for the day to watch, and volunteer so they don't miss the next one.
https://www.sau.com.au/forums/topic/353404-deca-helpers/#findComment-5673187
Everytime i come down i help out where possible, generally the skidpan in the afternoon.
Its dead easy to help out and still have a go, just get whoever runs before you to do your job for your run then swap back :)
Good idea Kieran
https://www.sau.com.au/forums/topic/353404-deca-helpers/#findComment-5673200
This was tried in the past and was not taken up by many people.
thus was discontinued (hard to have a priority list for something like this.)
WE more often get partners/ friends those that want to compete usually enter or don't turn up.
Happy to discuss bringing this back if there is enough interest.
https://www.sau.com.au/forums/topic/353404-deca-helpers/#findComment-5673219
Just make it simple. If they're there on the day and assist, when the accommodation thread for the next DECA rocks up any volunteers from the last DECA are able to reserve a place in that same thread. They can't pay or fill out forms till the official thread and forms are available, but their name appears on the list with Ryan, Leon, Clive, etc.
If they don't reserve themselves between the accommodation thread and the official DECA thread they forfeit their priority entry and have to line up like everyone else.
If they don't pay within a couple of weeks, they get bumped off the list.
https://www.sau.com.au/forums/topic/353404-deca-helpers/#findComment-5673325
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
