I had a GCG highflow on my S1 Stagea making 240awkw and it went really well. With a better FMIC and tune it would have made 250 - 260awkw which is really quite fast. It was only doing track days and wanting to do a little low level motorsport that has pushed me to looking for 330 or so kw and I have got the RB30 conversion and Gt3540 etc etc well over $10k probably nearer $15k for the extra power.
So what I am saying is yes go for the GCG highflow - you will need a Z32afm and bigger injectors 450 - 550 and a good tune. Easy stock looking install and you will make good power early on.You should be able to keep the stock fuel reg and bov (or maybe replace the bov with a GTR one).
i heard someone say something about 370z injectors the other day
http://www.ebay.com.au/itm/440cc-High-Impedance-Injectors-CLIPS-Nissan-370z-VQ37-/280646107260?pt=Motors_Car_Truck_Parts_Accessories&hash=item4157cfc07c#ht_2322wt_907
apparently they are drop in for rb25 neo motors
just thought i would add this seeing as injector upgrades were mentioned
Yer I said it, I've put 450cc 370z injectors in. The ones you linked aren't the same. That's why they come with plugs.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
