Hi all,
basically iv got an R33 GTST. At the moment iv got 18x9.5 +36 on the rear which fit with plenty of room. I have the guard lip completely cut out pre-emptively but n these puppies fit with plenty of room and i still run the minimum camber possible on R33 standard camber system, also car is lowered alot.
so now im looking at putting 19x10 +10 on the rear. Is it possible? any body done this before? (photos?)
i dont want to run any more camber. But im happy to raise it up a bit in height (i have adjustable suspension) so it doesnt hit the guards like it does when its low. Also able to put on the arch flares so that it doesnt look like the rims stick out further than the body.
any thoughts on all this? particularly actually getting them to fit...
cheers people.
https://www.sau.com.au/forums/topic/353995-can-i-fit-these-rims-on-an-r33-gtst/
http://www.1010tires...tcalculator.asp
Dont think its a very good idea
according to this your new wheels will sit 32mm further out then what your current ones do.......
From what I know a 10" +10 offset is a GTR fit
Edited by 89CAL
lol yes it can fit, dont need "gtr" guards BUT if you dont want any camber etc then no it wont without arches which will look homo.
so really id say dont bother cos what your describing will look bad
  • Like 1
thanks for all the replies people.
yeah begining to err on the side of too hard basket. sounds like it will be a mission and even then it may not be a good outcome...
however if anybody has any pics or direct experience with fitting this typre of rim to an R33 GTST id be dead keen to hear about the experience...
its 100% possible but not with out camber/low if you leave stock hieght etc it will hang out considerably i've got 18x10+20 with heaps of room could easily fit a +10 being 19s wouldnt make much difference other than the car will overall be higher.
mmm, cheers for that alex.
you mean heaps of room after cutting/rolling the guard lip? also what camber do you run.
iv considered the whole lifting it up aspect cos iv got adjustable. Definately something id prefer to do before throwing camber at it and consequently wrecking good tyres as well as my ability to get the power down...
ive got 18x10 +18's with 265/35 tyres. camber arms maxxed and rolled guards and the top of the wheel just sits inside. so you'll have to have you car raised abit but will still stick out. cops will pump u for it anyway.+22 would be a better fit to reduce the camber and have the wheels sitting in the guards a bit better.
Sounds abit extreme to me IMO. But yes they will fit. How they will look is another question. Very mexican.
I have 9.5 +25 on my R33, and they are not entirely in the guards. Thats with rolled and slightly pumped rears too.
yeah i decided against it.
Deciding piece was I saw a guy rock up to buy a part off me n he had 18x10+22 on his gtst which sat real mexican n realised its not my thing (especially when thowing in the cop bait factor).
cheers for all the info and perspectives people.
just need a GTR now so i can get those epic rims.... :)
what does fit nice involve? can you see the rims when looking from the back down the line of the body (as in are they sticking out form the arches mexican style?)
n hows the camber wear and traction too?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
