Hi mate, u mailbox is full so I cant send u any PM now............. Plz do something
Ok guys, since I have bought my new car and am selling the R34, up goes for sale a heap of stuff I had acquired but never had time to fit:
Brand new Arospeed adjustable car gear suit RB25DET $125
Brand new genuine Carbon Fibre R34 eyelids $100
Slightly used R34 fibreglass eyelids (need paint) $50
Slightly used R34 fibreglass front lip (slight damage to a rear corner - would not be notiecable when fitted and could easily be fixed when painting) $100
Brand new Tomei heay duty valve springs (rrp $600) suit RB25DET NEO $350
Brand new Malpassi rising rate fuel regulator with pressure gauge incl. all hardware/instructions to install $200
Brand new Uras steering spacers (gives you 15 degrees more at full lock) $30
Brand new D1 Spec Radiator Breather Tank incl. fitting accessories $50
Stainless Greddy Copy oil catch can and fitting accessories $50
Slightly used Pivot digital water/oil temp gauge and fan controller $100
5mm non-hubcentric wheel spacers $15 per pair (I have 2 pairs)
Red (with led) missile switch $10
Series 1 Air Flow Meter (green label) $50
unknown condition, bloke i bought it off on here said it needed some of the plug pins re soldered but they look fine to me and i dont have a series 1 engine to test it on.
Series 1 Coilpacks (stock) $90
bought em for my engine but found out i have a series 2 donk (no they arent splitfires)
Series 1 Coilpack Loom $50
same as above
Series 1 Coilpack ignitor $80
same as above
rb20/rb26 Coilpack Ignitor $80
was on my gtr motor but i parted that out
R33 Series 1 ECU $120
need a series 2 ecu instead
pm me any questions etc
17" Magnel rims 5 stud
At work atm so cant remember wat brand of tyres are on it, however, 2 have minmal tread and other 2 are fine.
from what i remember i think they are 17*7 and vaguely remember tyres were 225 and other pair 215.
Looking for $500 ono or will swap for anything out of interests (except for rims-thats why im selling these :lol: )
Price drop!!! $400 !!! Make an offer need them gone!!!! got bills to pay =[
Make an offer!!!
rb25 motor s1 blown head gasket complete minus turbo $400 ono Now $300 (Sold pending payment)
s2 blown turbo (rear wheel snapped off) good for highflow $50
r33 s2 loom $100 perfect cond. $80
r33 s2 airflow meter $150ono SOLD
r33 s2 stock ecu $50
split dump pipe suit rb20/25 $60 $40
r33 shell, rear drivers side damage, minus front panels and chasis used to repair crashed 33, still rolls just lol $200
r33 type m side skirts and rear pods small on 1 skirt and 1 pod damage, yellow in colour $60 the lot SOLD
r33 rear window $100
r33 rear pod windows $60 each $100 for both
r33 s2 wing been sanded back (was gona paint) good cond. otherwise $100ono
r33 s2 steering rack $200ono
r33 door trims front and back $30 each $100 for all 4 $50 the lot
r33 dash $50 $40
r33 rear parceal shelf good cond $40
2x r33 stock intercoolers $40 each
Come on guys i want this stuff gone just taking up space
will put pics up on request pm or phone me 0423904934 cheers jarad
LST 2 Features:
  • Potent new Mach 427 engine
  • Newly-designed driveshafts and axles for added strength
  • Revised suspension arms, hubs, carriers and spindles
  • 20mm anodized aluminum wheel hexes
  • Mega shocks with threaded anodized bodies and adjuster nuts
  • Losi Spin-Start Electric Starting System
  • Exclusive Multi-speed transmission w/reverse and slipper clutch
  • Sealed 2-speed spur gears
  • Steel-geared vicous differentials
  • Bulletproof aluminum F/R differential cases
  • 420-series dish wheels
  • Low-profile ATX racing tires
  • Aluminum clutch shoes
  • High-capacity fuel tank
  • Dual-disk brakes
  • Pro-tune linkage set
  • 1100MAH Ni-MH receiver battery pack and 110V charger
  • Premium JR XS3 Synthesized radio
  • Dual metal-geared Z590 steering servos
Specifications:
Type: 4WD Nitro off-road truck
Scale: 1/8
Width: 18.5 in (470mm)
Wheelbase: 14.2 in (361mm)
Weight: 13 lbs. (5897g)
Chassis: Dual-deck aluminum with composite ladder braces
Suspension: 4-wheel independent H-arm
Drive Train: Center Hi/Lo trans, 2-speed w/slipper and 2 differentials
Tire Type: ATX low-profile racing tires
Motor or Engine: Mach 427 (.427cc) with tuned exhaust system
Radio: JR XS3 Synthesized FM system
Servos: Z590 (steering x 2), Z270 for throttle/brake & shift
Batteries: 1100MAH NiMH receiver pack
Charger: 110v, 100MAH overnight charger
Speed: 40+MPH
Wheel Size: 40-series using 20mm drive hex
Kit/RTR: RTR
Shock Type: Oversized threaded coil-over mega shock
Body: LST2 Racer type, prefinished
Ball Bearings: Complete
Fuel Tank Capacity: 220 c.c.
few spare suspension parts and wheels fail safe not used for about 6 months last run fine reverse disconnected but easily reconnected
$500ono
Edited by trdsv21
Work Emotion Xd9 18x9+20 (215/40/18) 18x10+18 (235/40/18)
Putting my Work's up for sale. I can guarantee you that you will get pussy if you put these wheels on your car and if you don't, you should be giving up on pussy all together.
Would fit perfect on an R33/R34 will need a flare on a R32. Fronts have a few marks on the rim from the old owner who apparently dropped them when fitting tires. Tires on the front are Dunlop Direnza with 85% tread (mark on one from guard rubbing on tire from old owner) and the rears are brand new still in the box and I've just got some Kuhmo KU31 tires in for them yesterday, I haven't fitted them yet but I can if need be.
In all honesty I just want back what I've paid for the wheels, so basically your getting free tires with them. Don't want any low ball bullshit offers either. Fronts were on my car for two days then I got defected so they came off. If you want some quality dished jap rims for your car these are what you need.
$3,000
$400 or make me an offer for 4 of these...
They came with my stagea when I bought it, appear to never have been used so 100% rubber etc. I don't want them and they are just taking up space in my shed. I'm in the Port Adelaide area.
PM or email [email protected]
Cheers
rb25 motor s1 blown head gasket complete minus turbo $400 ono Now $300 Sold pending payment
split dump pipe suit rb20/25 $60 $40 SOLD pending payment
r33 dash $50 $40
OEM coilpacks for sale, there are two sets, i think there is about 3 or 4 that dont work, but i don't know which ones. One set has a fair bit of silicone over them. They suit RB25 DET NEO. $120.
R34 GT-T stockies, rims have a fair bit of rash, would be nice painted black. Tyres are average. Pics to come soon. Centre caps included. $300
Megavox 12" 400W sub, unsure of age, its in fair condition. $40
Standard R34 Pioneer Carozzeria CD/Mini disc player. Is in good condition, loom attached. $50
R33 Turbo, suit rebuild, or doorstop. $50
R34 GT-T standard springs and shocks. Have passed regency, so are still in good condition. $150
R34 standard dump pipe, good condition. $50
Make: NISSAN
Model:SKYLINE R33 Series 1.5 Mspec
Year: 1995
Milage:190,XXX
Transmission: MANUAL
Colour: SILVER
Complied? YES
Currently registered? YES
Price: $16,800 ono
Contact: 0435 192 164
Modifications:
Stock rb25det series 2 engine
- Tomei adjustable exhaust cam set to 2deg advance
- Hks Gt2530 Turbo Kit
- Hks 3 "Split dump
- Hks 3 "Front dump
- HKS Hard intake pipe
- 3" Stainless Mandrel Bent Magnaflow cat back exhaust
- 3” Decat
- Pod Filter
- Silicon hoses and lines
- Trust FMIC
- Z32 AFM
- Nismo FPR
- New Yellow Jackets coil packs
- Bosch 044 fuel pump
- Apexi Power fc + Apexi Commander
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller
- Exeddy Clutch Kit
- Lightened Chromolly Fly wheel
- Pro-Stopper Series 5 Alarm
- Triplex Immobilizer
- Head Unit - Eclipise 50x4 CD5444 CD/MS Receiver with MP3/ATRAC3
- Kenwood 7x10's 350watts
- Nismo 400r Sideskirts
- Nismo Clear Side indicators
- Alpine V12 Amplifier
- KYB Coil Overs
- 19" x 9.5 Starcorp Racing Impuls deep dish with new tyres
- 20% Tinted Windows
- Twin K&N oil breathers
Car makes 240rwkw on 17.5psi, is always garaged and serviced with motul synthetic oil, engine has been rebuild, compression test etc welcome.
Excellent power and response in every gear, no lag.
Or 11.5k without 19" wheels, power fc, blitz ebc, z32 afm, coil packs, hks exhaust, nismo fpr, hks turbo kit & hard intake pipe.
Some pics, now has deeper dish on front as well and the nismo clear indicators not seen in these pics
Brand New Work VSKF wheels in Shadow Chrome Fronts 9.5 R Disk +26 Offset, Rears 10.5 R Disk +30 (Both front and rear have 2nd hand Potenzas on the 225's on front and 245's rear with about 80% tread on both) 3.1k
Brand New ISC 20mm Spacers - $120
Brand New Blitz Twin Plate Active Clutch Model Number 65252 Suit GTS GTT and GTR (Nengun Price AU $ 2,067.96) Im asking $1400
Brand New Blitz LM Spec FMIC For 33GTST (Nengun Price AU $ 1,326.52) Im Asking $800
Brand New Blitz Dual SBC Spec R Electronic Boost Controller (Nengun Price $ 591.49) Im Asking $400
Brand New Blitz Fatt DC IV Turbo Timer $100
Brand New HKS Split Dump Pipe (Nengun Price $ 410.05) Im Asking $320
Brand New HKS Stainless Steel Front Pipe Nengun Price AU $ 526.10) Im Asking $400
Brand New Sard Torque Control Valve (replacement cat with a flange inside to increase torque at low revs, Nengun Price AU $ 381.66) Im Asking $300
Brand New Grex Oil Filter Relocator Kit With New Greddy Oil Filter $130 as theirs a couple of marks on one of the hose ends
Brand New HKS Timing Belt (Nengun Price AU $ 207.86) Im Asking $160
Brand New Apexi Super Suction kit (Pod Filter With Brackets and Alloy Intake Pipe To Turbo, Nengun Price AU $ 499.01) Im asking $380
Brand New Bosch Z32 AFM With Harness - $250
Brand New Apexi Power FC (Still under warranty) $1400
Brand New Nismo Fuel Pump In The Box (Nengun Price AU $ 533.39) Im Asking $450
Brand New Cusco Drag Rods In The Box (Removes Hicas unit and replaces stock tie rods with thicker ones, Nengun Price $ 433.64) Im Asking $320
Brand New Nismo Engine And Gearbox Mounts In The Box $300 for the set
Brand New Genuine Uras R34 D1 Spec II Front Bumper (Uras.com.au Sell these for $649) Im Asking $350
Brand New Nismo Gear Knob The White Duracon one Still in its box $50
Brand New Focal Poly Glass 165 V-Edition Splits in The Box - $250
Brand New Focal 165 Al Rear Coaxial Speakers In Box RRP $219, Im Asking $140
Brand New Audiobahn A6004T 4 Channel Amp $200
Brand New Optima Yellow Top Battery $300
Brand New Front And Rear Whiteline Sway Bars The same models from the SK group buy (Front is blade adjustable, rear is fixed) $350 for the set
Brand New Whiteline KCA347 Rear Camber correction Kit - $100
Brand New Super Pro SPF1483K FR control arm lower inner Bushing $80
Brand New Mongoose m80AU Alarm In The Box $200
Brand New Uras Super Pineapples (uras.com.au sell these for $245) Im Asking $130
Nismo 555cc Injectors, Roughly ~5000k's usage - $350
Apex EL Guages Boot And Exhaust Temp (needs harnesses) $60 for both
HKS Pod Filter For GTR which has been modified to suit GTST - $20
Greddy Catch Can (square Type) Great Condition - $70
Cusco Break Stopper Great Condition $90
Splitfire Coilpacks Great Condition To suit Series 1 r33gtst - $350
Custom Heat shield Box For Pod Filter Bought from Maxx here ages ago (needs screws and the clear window has a crack in it but can be easily replaced) $100
Blitz Nur Spec R Catback Exhaust - Bought Brand New used for about 1500k's Has a scrape on the bottom of the rear muffler and a dent on one of the hotdogs $300
Nismo MDF Screen With Epson EJ1 ECU The complete kit with remote - $1300
Auto meter Shift Light $60
Series 3 R33 GTR Front Seats, Bought these from Japanese Import Spares only a few weeks ago for $1200, Asking 1k
Brand New Nismo Clear Indicators In The Box (Nengun Price $ 84.04) Im asking $60
Work RS Red Wheel Nuts Good Condition $160
Brand New EBC Green Stuff Pads - $120
Motus 300v Chrono Oil 2L bottle Opened and used maybe 200ml of the stuff - $25
Slide Highflow Turbo Bought this off another member on here, its meant to have a VG30 housing but i never had that confirmed it made 264kw on his car VGC, comes with oil and coolant lines - $750
R33 S2 Rear Strut Brace - $100
Rare Tomei 3pt Strut Brace - $200
Nismo TT 2 Way LSD, Bought off nigel on these forums but never got to use it - $750
Nismo Oil Cap Bought (genuine) Brand New Put on the car so no box for this one $70
Genuine Bride Seat Rail, Brand New Condition to suit skyline for Brixx and Ergo II seats - $150
Now the only catch is that a lot of this stuff has been put on my car during the whole build up of the car which i never completed, so depending on what you want it might take a week or so for me to get it off. Im going to leave this for sale add on here for a week before i advertise it on the main forums as id rather sell most of this stuff locally, Prices Are firm as their already heaps cheap as they are!
Contact Me on Pm Here
Edited by /2on
RON I cannot believe you are stripping your project would have loved to see it on the road! You hand picked such a good selection of parts that would have worked so well together!
PM Sent
Anyone looking for a choice diff upgrade should buy that Nismo 2 Way its basically new and very nice to drive on I only sold it as went crazy and spent $2000 on a ATS Carbonetics one to match my ATS Carbonetics Twin Plate Clutch.
Edited by nigelswazi
hey guys got a set of Gold Drift Teks for sale
17x8 front +34 17x9 + 35 rears
5 Rims altogether minimal rash on 3 of the rims
they are 5x114 stud
looking for $1200 or swap for 4 stud drift teks
pics: http://i460.photobucket.com/albums/qq328/f...26/DSCF1239.jpg
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
