Need to sell:
* $100 for 2x JDM S15 450/480cc injectors
* $100 for 1x drivers seat, Ghepardo, black, reclining, adjustable, new, super comfy, bottom mount but no rail
* $9000 for 1x Daewoo Nubira 4-door sedan, 29000kms only, 5spd manual 2.0Lire 4cyl economical 100kw engine, leather interior, 4wheel disc brakes, allow mags
Spalding GOLD series basketball ring portable, spring loaded!!
im selling my basketball ring, as its at my old house and theres no room at where im living now or where my house will be built, its the GOLD series which has the biggest base, biggest backboard and it just general better overall compared tot he silver and lower series, i paid $440 i think it was on special, currently the silver version is on special for $350, mine is assembled but can be slightly disassembled for a buyer ( still most prob need a ute to move) ive had it only a few months great condition will sell for $350o.n.o,
FS
2nd hand MWB brand (japanese) boss kit to suit nardi/momo steering wheels.
NOT hicas compatible - suitable for anyone who has a hicas lock bar or non hicas car.
Has a crack in the surround which had been repaired before I got it but the glue has come away from it.
$20 or trade for a few longnecks of beer
-D
Selling my Apexi Power FC AP Engineering for an RB20, bought it to put onto my Cefiro but im selling the car now so no need for it anymore.
Shoot me a PM if interested, wanting $1100, no hand controller but you can purchase them from Greenline ect
Thanks
Dirt Bike
I'm wanting to sell my '98 YZ250
Good condition
Clark fuel tank
Selling due to it only being ridden 5 or 6 times in 2 years
Looking for $1800ono Can possibly organise a test ride somewhere. Bike is Located in Gawler.
Dirt Bike
Good condition
Clark fuel tank
hey dude any chance you could sent a pic to my inbox at all :P
Howdy guys, my DTM Rush wheels are up for sale again by the looks aha.
They are 18x9.5 +27 painted in satin black with a full set of 255/35/18 with 90 - 85% tread
I am after $1,600ono. for the whole set and beleive me when they are clean they look stunning!
Tinyest bit of rash on one of the wheels lucky to be like 3cm all up and is a really really light graze.
Can get more pictures apon request.
Contact me via PM or ring/txt on 0433830055 :D
Wayne.
They'll hang out majorly on the front.. might need a bit of work on the rear too..
the front fenders have been replaced with massively pumped and rolled out guards, 9.5 +27 should be sweet there, would need a few good deg'z of camberz
on the back it will deffo need some massaging, but guys run 10" with similar offset without too much hassle.
but with the stud patern fit?
edit***
18x9+20 and 18x10 +18
Edited by rhys5169
Man on a JZX100 18x8.5 pretty much sits flush with the front and a 9 is flush with rear. You'd need a dickload of guard work. Stud Pattern is all good. I'd suggest finding someone with similar sized wheels and test fitting before buying them.
without doing any research, can someone tell me if them rims ^^^ will bolt up t a jzx, they will fit in terms of size (maybe a little guard love) but bolt space?
my mates car with my wheels 18x9.5+15 all round and 235/40's (so stick out 12mm more than the ones you are looking at)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
