i may have a buyer for them Carl, ill let you know
cheers damo
let me know ;)
carl, i have a couple of pairs of standard s3 headlights if ya get stuck alright ;)
might hit ya up on that. if so ill bring it down. has no screamer tho YET. :(
Compaq Presario CQ61-107TU Notebook PC (NW982PA)
RRP is $999. Brand spanking new in box, not even opened or touched. Ill let it go for $800, FIRM.
Specifications can be found here. http://h10010.www1.hp.com/wwpc/au/en/ho/WF...29-3938413.html
PM me or email: [email protected]
$750
Compaq has released a new version of this laptop, pretty much same hardware/software. Both running Vista premium. new model is CQ61-214TU, rrp $999. asking price dropped accordingly
eoi
willing to trade for some different rims if anyone is interested send me sum pics with sizes and offsets.
mine are starcorp impuls 18x8.5 and 9.5 (+38 i think) with near new tread. silver face and dish.
must fit skyline studs. cheers
All parts are located in Adelaide. All prices are for local pick up. can post at buyers expense.
Work Xd9's
front 17x8.5 +25 with 215x45 tyres, in good condition
rear 17x9.5 +17 with 235x45 tyres, camber wear from previous owner.
comes with a set of new blue anodised work wheel nuts in box.
$2100 with tyres and wheel nuts
Malpassi rising rate fuel pressure regulator
brand new, never used comes with brass barbs
$120 ono
Fuel Swirl pot.
custom made 3 10mm lines, 1 12mm line (284mm x 70mm)
from memory, its TTr2xheight= capacity. all the important info is there for you to work out total capacity.
$100
S13 washer bottle
in good condition, can get more pics on request
$30
Also have an Apexi AVC-r stand.
mine got taxed. no need. also got box if someone wants that with the stand?
$50
Genuine Titanium muffler
some scratches. came off Uncle Marky's (Exhaust technology) S15 when it was yellow. comes with 3inch pipe clamp.
$150
T25G from redtop SR with manifold and dump
no back to front movement
alittle side to side.
$120
any further questions or requests for more pics via PM please.
Cheers
Wil
Hey guys want this stuff gone asap.
Metalic Silver Fibreglass bonnet for R32...exactly the same as in pic but fibreglass instead of carbon fibre - $400
Full 6 point Cusco roll cage for R32..immaculate condition - $850
Cusco front strut brace for R32 - $150
ISC rear camber arms for R32 - $150
Veilside 1 piece seat with R32 rails and harness...not willing to separate rails. Will bolt straight in - $400
If ya interested send a txt and il txt u pics because i cant get on here all that often.
Cheers,
Chris
0400 259 598
Cearing out the garage again in time for the new project
r32 front heater core, all air con piping and air con pump with bracket. basically everything u need.. $140 ONO
rb20 alternator. $40
rb20 crossover pipe with bov. $80
standard rb25 engine mounts with no bushes. $25
rb20 rubber intake pipe. $25
rb20 turbo. was leaking a bit of oil but minimum shaft play $60
rb20 front fan, not sure wat its called, runs off the engine. i think its called clutch fan? with the plastic cover around it but covers got crack up top. $40
rb25 standard clutch $25 or if u want a week ill have a flywheel aswell and u can have both for $90
rb20 exhaust manifold. looks ok condition. $25bux
some random blue/black drift brand steering wheel. good condition $15
txt or ring me on 0428851616 or pm me
cheers
Hey guys got a HKS GT25/35 for sale.. was going to put it in my skyline but lost interest in the car... so this turbo upgrade has to go.
HKS GT25/35 bought it of a member on SAU not long ago.. comes with dump pipe and stainless steel intake pipe to pod. doesnt come with any lines.. the turbo has very very little - no shaft play but every ball bearing turbo has a tiny bit shaft play, correct me if im wrong. looking for quick sale $1200!
no need for pics you all know what turbos look like. located in paralowie.
Got the following for sale:
KTS Tie Rod Ends, pillow ball suitable for A31, C33, R32 and R33 (RWD) - $100
Looks like so but filthy dirty as its been on my car:
Cusco Type OS front strut bar for an R33 - the blue end plates have been sprayed black therefore it is now standard and not an aftermarket mod - $100
Expressions of Interest
Group Buy - Siemens Deka fuel injectors
I ordered 6 injectors from Miami last fortnight and they arrived here in rapid time. Ended up costing me $360 for a set of 6 575cc injectors for my RB26dett (low impedance, top feed). A couple of members here are considering getting new injectors, so I was wondering if anyone is keen to join the purchase and maybe get a discount (maybe... $360 is pretty cheap as it stands, as it's half as much the australian distributors want for the exact same injector).
Sizes are from 300-1300cc, top feed only but either low or high impedance
PM me if you're interested - this is a once off and I won't be doing a repeat order.
-D
EDIT - He does do RB25 Neo injector top feed conversion packages for around $600 that include a fuel rail, 850cc injectors, ev6 and ev1 adaptor and seals
Am placing orders on Wed. Pm me asap if you want in on this order
-D
Following for sale...
A GReddy, two gauge A-pillar holder (60mm) to suit 33 GTS-t/GTR. Bought it not too long ago to fit my new Defi's in but ended up mounting them on the dash using the stands. Perfect condition, nothing wrong with it. I only ask what I paid for it, $100
SOLD
tie rod ends sold pending payment
strut bar still got sale........
Ceffy headlights S1 - $150
Ceffy Tail lights S1 - $100
Non hicas cradle - $150
all rear stock suspension arms - $50
SR X member - $80
S13, A31, R32 steering rack - $70
Stock S13, A31 suspension - $250
Front LCA's - $50
Rear LCA's - $50
stock castor rods - $50
complete ceffy interior - $100
R32 rear seats, m spec series - $50
A31, maybe R32 steering shaft - $100
ignition barrel with key and wiring (great if your car been broken into) - $75
ceffy front guards - $120 pair
ceffy rear window - $250
R32 lhr tail light - $40
R32 crash pad (dash) - $70 (1 or 2 bubbles in it)
SR20DET starter motor - $50
A31 BMC with booster - $60
A31 clutch master cyl - $40
A31 clutch slave cyl - $20
RB20DET intake manifold, complete with rail and injectors - $140
RB20DET injectors - $60
RB20DET head - $150
RB20DET coilpacks - $150
R32GTST pedders suspension lowered to 340mm eyebrow height - $250
ceffy front rad support, great for crashed car - $100
ceffy doors with glass and all electronics - $75 each or $250 for all four
call or sms on 0417 084 405 or pm me
i have lots more R32 interior panels aswell
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
