As title says
adrenalins all tyres are shagged 17x8 i think $2oo firm
kts have 235/45's good for a skid and other 2 shagged 17x7 $350
Both are 4stud 5x114.3
R32 stockys all painted with can, 2 black 2 silver tyres not well. $100 firm
South Adelaide.
so there 4X114.3....
Item: Wolf 3D V4 (V400) Revision 7, Comes with loom plug and part of a loom (so you don't have to destroy your own) does not come with Hand Controller.
Condition: Works perfectly, a few scratches and a bit of glue where a sticker was removed, apart from that it is in as new condition.
Price: $850 ono
To Fit: R33 GTS-T with RB25DET or R32 skyline, it is plug and play for R33, with R32 a few modifications need to be made.
Contact: Roland on 0423 277 771
Here is a link to the full thread with pics etc: http://www.skylinesaustralia.com/forums/sa...ml#entry5144467
QUOTE (PROXIMITY @ 22 Mar 2010, 01:25 PM) *
As title says
South Adelaide.
My bad lol, yes they are 4x114.3
Items:
1995 (AE101R) Toyota Corolla CSi Sedan 1.6L Auto (Panama Blue)
Item Condition:
166,xxxkm, reliable and fuel efficient 1.6 litre engine. Has extractors, towbar, Alpine detach face CD player. Minor wear on drivers seat back cushion outer edge (easy to repair, happy to get repaired before purchased). Full service history (my parents are 2nd owners since new)
Extra Info:
Good reliable car that is needing to go to a good home. Mum has bought a new car so it needs to go. Has rego till the end of May
Contact Details:
Via PM
OR
Mobile - 0409 049 299
Price and price conditions:
$3500 ONO
FOR SALE:
PowerFC + commander unit to suit R32/33 GT-R.
PFC unit is marked for a R33 GT-R but is also good for use with a R32 GT-R.
I only bought it a short while ago, but I don't know when I am going to get it tuned so I thought I'd put it up for sale should it not sell I don't mind but if someone has cash then I'll let it go. The commander unit has a few light scratchs on it, nothing bad 'just looks used' is the best way I can explain it.
Sale price is $700 - wont sell it for any less so dont even bother asking, As I said I'm not fussed if it doesn't sell but if its just going to sit there I'd rather the money to be honest lol.
Contact me via 0433830055 or PM me.
Cheers, Wayne.
I have also got a full set of 4 Bridgestone Potenza 245/45/18's
They all have legal tread, couple mm above the wear bars, I bought them to stretch on my wheels but without thinking the '45' profile is too big for stretch and won't really work but for someone that isn't going for a stretch etc these will be great.
$100 firm! No budging as this price for legal tread potenzas is crazy.
0433830055 < NEED THEM GONE!
for sale pair of semi slicks
265 40 r17 they have about 5mm tread left there still about wear markers, good for a track day, id use them but
they just wont fit under the silvia guards with the offset of the rims haha
there dunlop formula r's model is a SP SPORT DO1J
for pics msg me 100buks firm
also have
silvia brown dash $20
whole aircon set up out of s13 sr20 compressor with bracket, lines, condensor, reciever dryer etc $50
apexi power intake, came off sr20 afm with apexi pod filter $50
sr20 afm $40
r32 lower control arms $40
r32 std front susp $40
r32 front nuckles with 5stud hubs bearings feel good $50
or take it all for $100 firm
blitz 60mm boost gauge, black face measured in bar, good nick $50
pair of nissan stockies, 4 stud 15in good for skids $20 no tyres
pair of 15in r32 N/A stockies 4 stud with shitty tread $30
series 1 r32 steering wheel with horn button $40
cannon 3in inlet bout a 4 or 5in tip bit banged up but good for track car came of s13 still has stays on it $20
r32 rad fan shroud $40
r32 under engine cover plastic thing $40
s13/180sx std front and rear suspension $80
if you want pics of anything pm me with ur number and ill send them on to you
need to get rid of this fast so throw me an offer if your not happy with the price thanks
-Adrian
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
