RB20DET Coilpack Loom - good condition, no misfires. - $50
RB20DET Ignitor Module - $50
RB20DET Injector Resistor Pack - $10
RB20DET Turbo + Exhaust Manifold - I never had a boost controller so was running on stock boost. - $100
RB20DET ECCS Inlet Manifold - complete with injectors, fuel rail, throttle body etc. - $100
PM/SMS. 0438858813.
PM/SMS. 0438858813.
RB Flywheel $50
Gearbox Sandwich Plate $10
R33 Speedo Sender $50
Clutch Throwout Bearing (NEW) $35
RB20DET Gearbox Yoke $50
SECO Pressure Plate $50 (Jim Berry rebuilds these for his clutches)
R32 Starter Motor $20
RB20 Dump $20
NISMO Clutch, pressure plate is machined, $50
RB20 Ignitor Module $50
RB20 Crossover Pipe, with BPV attached $50
RB20 Turbo + Exhaust Manifold $100
Exedy RB Chrome Moly Lightened Flywheel (Freshly Machined) $350
Xtreme Heavy Duty Cushion Button Clutch Kit for RB $300
Driven 15,000 kms, upgraded due to more power
Lightened Flywheel + Clutch Kit together $550
PM or sms/call for info 0413 733 433
located in adelaide, aberfoyle park
all offers considered.
R32 Tein HA Coilovers
Damper and Height adjustable
$500
R33 Tein Ha Coilovers
Height adjustable
$500
R33 Cat back exhausts
Twin pipe setup, $300
Kaikamoto (spelling) $300
R32 Indicators (orange)
$100
RB20/Rb20 S1 Coilpacks
$100
R33 Turbo/Manual Diff
$150
R33 Brakes, Front and rear
$500
R33 5 Stud hubs, Front and rear
$80
Also Check:
http://www.skylinesaustralia.com/forums/R3...13-t315266.html
http://www.skylinesaustralia.com/forums/Ni...13-t318919.html
http://www.skylinesaustralia.com/forums/R3...ff-t320107.html
Edited by JiN_MaN
For Sale:
Left and Right hand side 12 inch subwoofer enclosures made of fibreglass, fits into the corner of ur boot looks good.
Fits r34, dont think u will find them in s.a!
Asking 180$ for the pair!
For Sale:
Got pics mate?
17*8 Drift R by ROH Megs 5 spoke 114.3 pattern.
Well looked after mag wheels. Black power coated spokes with polished lip. Paint on one of the wheels are comming off in the centre but other three wheels are in perfact condition. Two of the wheels have very very small gutter rash see picture, unoticable. $300.
Also have r33 gtst stock closover pipe with GFB BOV great working order. $100
R33 gtst stock cooler great condition for $50.
Feel free to contact me here or 0412724796.
cheers.
P.s I was trying to upload some pictures but somehow it got lost. I can suply pictures up on request via PM. ta
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
