z32 afm SOLD pending payment
for sale:
1x HKS EVC-3 electronic boost contoller, complete setup with harness wires, unit, solenoid - $150
1x 240sx S13/S14 12.75" 324mm brake bracket adapter setup, suits 350z front discs & 300zx calipers on Silvia - $150
Just bought but they dont fit my motor.
Flow tested at 580cc at 3 bar fuel pressure (factory fuel pressure).
Direct drop in for RB25, Red Tops, unsure what brand, look like nismo but unsure.
Details:
JECS
Made in Japan
A46-00
0C55 3722
$450 (will consider swaps for RB20 550cc+ injectors)
For Sale
R33 GTR Turbos, Manifolds and dumps.
Currently fitted to my RB25DE i was running 13psi and had 240RWKW, i want to drop a forged RB25 in and bo for bigger power.
These turbos weren't smokers and made good strong boost with no dramas, the wastegates are also in good condition.
Open to offers but keen to move them along ASAP so i can start my build.
If your interested please call or text me on 0401 337 481.
Cheers BJ
i would keep that setup on the forged engine and get nice GT2860 -7
are the turbo manifolds stock with modification or complete custom job
Hey Madaz,
There's no major mods but the person that put them on put some tabs where the other holes are on the DE head so it would bolt up, it doesnt leak and makes reliable boost so no problem there :laugh:
As far as the bigger power goes, i'm not going bigger and better twins because i've got a rebuilt 600hp "Independent Turbo Specialists" with a smalled rear housing that would work pretty well on a 25 :)
Alright, i have a KAAZ 4.11 ratio 1.5way mechanical diff out of my car. it's a great diff, i wouldnt be selling it if i didnt need the $$. i drove around with it as a daily up at a ski resort where there was ice, snow and wet everywhere and didnt have any issues with it slipping or skipping around tight corners or anything, barely anything with 3 point turns either. but on the track it was beautiful, no signs of any open wheeling, extremely predictable, with great turn in.
this comes with an R32 housing, and half shafts, so ready to bolt straight in, dont have to take the centres out.
$880
Located near Mitcham in SA, can send anywhere in Aus at buyers expense.
here's some pics of the actual diff:
http://i79.photobucket.com/albums/j121/nisskid/IMG_0848.jpg
http://i79.photobucket.com/albums/j121/nisskid/IMG_0849.jpg
Price drop $9000 as is.
It also has aftermarket fuel pump
pineapples on the rear
tinted windows
For Sale
Skyline R33 series 2 1996
list of mods
18"VR5 mags
slotted rotors with blue painted calipers
cusco front strut bar
gtr rear strut bar
non hicas rear cradle
turbotech boost controller
turbosmart plumb back BOV
HKS front mount intercooler
Garret TB3401 big low mount turbo
3" stainless exhaust from turbo back
oil catch can
fuel pressure regulator
mines ECU fuel,boost and speed cut
short throw short shifter
extreme heavy duty clutch
greddy turbo timer
ISC coilovers 2000kms old
body kit
Boost gauge on pillar
oil and water temp and volt gauge in dash
sony stereo with 6x9 explode rear parcel shelf. 6" explode doors and kenwood 12"sub in boot on custom backing
alarm
Very rare factory wood grain dash and gear surround. wooden handbrake lever and gear stick knob. I have never seen this anywhere else
Ive had the car for 5 yrs and serviced every 5000kms
Last time car was on the dyno it was pulling 260rwkw with a stuffed CAS. It would do more than that now.
Its been a great car Im just moving on to better things
Bad points
I think there is a head gasket problem. The radiator overheated once I thought it might of been from the head gasket. I put a bottle of copper liquid in it and it stopped (car still boosts fine but it may need to be looked at in future) and the gearbox has a slight crunch between 1st and 2nd
Im looking at $10000 as is or $12000 with another motor and gearbox as a spare in exellent condition ready to be swapped.
Also has a taller ratio diff gets higher speeds.
If you would like to know more you can PM me or 0427999093
http://i533.photobucket.com/albums/ee334/r...ds/P1050569.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050580.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050577.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050579.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050573.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050572.jpg
http://i533.photobucket.com/albums/ee334/r...ds/P1050575.jpg
i know someone who would be intereted in the z32 airflow meter if it falls thru
cheers we'll see what happens
also For sale:
to suit RB26 GTR
* HKS 87mm pistons & rings, fitted, used for under 100kms
* Attkd rods, fitted
* ACL race bearings - Part # 7M2428H-STD and Part # 6B2960H-STD = main bearings & rod bearings, new
* ARP main stud kit
$2000.00
includes Australia-wide postage
FOR SALE:
Item Summary: SPLITFIRE Coil packs pulled form a RB20DET.
Condition: Used, Not sure on KM but look like they have done many KM's few thou if that, No discolouring
Reason for Selling: don't need anymore, fitting RB25DET NEO
Asking Price: $400
Location: South Australia (Adelaide, North East suburb)
Delivery Methods: Pick Up or will deliver to most areas of Adelaide
Contact Info: phone 0422444532 Paul
Extra Information: Can be used in RB20 (R32), RB25 Series 1, RB26 (R32 & R33)
Hey Madaz,
There's no major mods but the person that put them on put some tabs where the other holes are on the DE head so it would bolt up, it doesnt leak and makes reliable boost so no problem there :down:
As far as the bigger power goes, i'm not going bigger and better twins because i've got a rebuilt 600hp "Independent Turbo Specialists" with a smalled rear housing that would work pretty well on a 25 :D
Located in the Adelaide hills, Near mount barker
For sale:
S14 Brake Rotors (280mm) and Calipers (4 piston). Front set only. Dont know what brand pads. $200
R32 GTR intercooler core, inside is clean, in decent nick. $100
R32 GTR standard radiator $50
S14 SMIC with complete stock piping $100
R33 rotors, freshly machined. $100 Firm.
S14 front and rear seats in excellent condition, with rails. $150
R34 Gtt, $21,000 neg link in sig
pm me. pickup in wingfield.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
