f/s-
i have a 38mm turbosmart wastegate.
fitted with a 7psi spring.
it held 15psi FLAT on my 25 with 3076r.
ONLY upgrading due to getting a craig helps merge collector manifold and HAVING to go 44mm or bigger :ermm:
used for 100km's
$300
up for sale my 32 CBF fixing it
up for sale is my r32,gts 4wd turbo AUTOMATIC.
black in colour
with 146000kms
rb20 DET
3inch cat back exhaust
17inch black r34 gtt rims
tinted windows
very clean body
bad points are little things like a few plastics in the interior are broken
NEEDS r/h side controll arm, front bar and tire to be swapped over as it has a puncture but i have a tire to go on.
and no rego but it can be all you have to do is go to the rego office and pay for it.
price is firm as its CHEAP as CHIPS , no swaps BUT i want a bigger turbo for my 33 so maybe cash a turbo and cash.
text me on 0415232397 located in mansfield pk
pics here...http://nissansilvia.com/forums/index.php?showtopic=463264
4 Sale
R32 ISC Rear camber arms, Brand spanking!
Bought coz they were going to on the track car but decided to take the ones off the streeter instead.
Bought for $179 (+15 bucks postage i think).
Sell for $150
z32 afm setup for 5-pin plug (suit Rb20, early-mid Rb25) still for sale - $100
I have some sets of Front Brake disc rotors (pairs) for sale:
1x DBA4000 296mm x 30mm 99% new. R32 GTR
unused from project, upgraded to 324mm set
had slight surface moisture rust, sandpapered off as per pic
$100
1x RDA 280mm x 30mm 90% new. R32 GTst, Stagea S1
had slight surface moisture rust from leaking shed, sandpapered off
$80
1x RDA 280 x 29mm 75% new. Stagea s1, R32 GTsT
$70
1x stagea S1 front brake caliper set, with braided line as pictured, new pads
$50
need it gone
thanks
FOR SALE:
Carbon bonnet for r34 300$
Blitz LM fmi return flow type r34/33 300$
R34 Nismo/Altia rear bumper, original not fibre glass copy 150$
pm me if your interested!
PM sent for bonnet and FMIC
cheers
for sale
genuine r34 aero front bar 500 neg
fibreglass aero front bar brand new still in gel coat, no pic 150 neg
brand new never been used greddy dual pillar gauge holder for r34 gtt/gtr 120 neg
msg or ring dylan on 0433091947
Bendix Ultimate Pads + Discs To Suit R33 Skyline
Includes:
Front Discs x2
Rear Discs x2
Front Pads x2
Rear Pads x2
Not sure on the true value of these, so if some makes a good offer i will probably take it
These are also listed on ebay at the moment, here's the link to view pics of the dics and pads
http://cgi.ebay.com.au/Complete-Set-Brakes...=item3a5f3a5ae5
The discs have hardly a lip at all on them at all, the front is like not even a 1mm lip i rekon,
And as for the rear discs, they just feel like there is no lip, just where the pad doesn't reach the edge of the disc its a lil rough, which is normal
The pads have 7mm all round front and rear, and they are Bendix Ultimate,
Do not want to post as too heavy being metal, obvious reasons ofcoarse. Would prefer pickup only
Contact me through here or send me an e-mail at [email protected]
Locater in craigmore 5114
r32 standard turbo. Came off the car running stock boost before I did a turbo/injector upgrade. $200.
Set of rb20 injectors $100
rb20 airflow meter $70
prices are neg. I am willing to swap parts for the following things--
Bonnet. Drivers side front guard. Drivers side head light and indicator to suit r32.
Pm for details thanks
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
