Versus rims
2 x 18 x 9.5
2 x 18 x 8
1 has slight gutter rash maybe 15cm long. Rest are in mint condition
Looking for $900 ono tires (3) inc but pretty worn.
Mobile: 0401 355 434
Pics
Price Drop $800 want them gone.
Up for sale is a set of R33 GTR sway bars.
I bought these off a while back and they don't fit my car(Auto)
They will fit manual C34 series 1 or 2 stagea.
the rear is 22 or 24mm solid from memory, a great upgrade over the standard 17mm hollow bar.
Selling them for less than i paid for them.
Rear sway bar comes with rubbers, u bolts and links to suit.
$150 + postage
Located south of Adelaide
Pm or call me - 0423 10 11 10
stock rear sway bar compared to r33GTR sway bar
N13 pulsar for sale!!! Got 15 inch wheels, whiteline front strut brace, lowered king spings with new shocks, exhaust! Keen to swap for some wheels to suit my 32! Open to offers and cash offers too.
msg me for anymore details or pics of the car.
Brad - 0430033573
100k service kit for GTT, I don't have the car anymore so no longer required: rb25det neo water pump, gates timing belt, tensioner bearing, idler bearing, 3x Ancillary belts
post-47337-0-94923400-1291524979_thumb.jpgpost-47337-0-36269200-1291525011_thumb.jpgpost-47337-0-72578400-1291525052_thumb.jpgpost-47337-0-98687800-1291525128_thumb.jpg
$400
Pm me or sms me on 0433348748 for further info..
$150 + postage
Would this bolt on to a R33 GTST??
If so then i am very keen
Set of Lenso D1R's with tyres and centrecaps, near new, no rash, excellent condition.
front: 17x9 +35, 225/45 tyres near new
rear: 17x10 +15, 235/45 tyres near new
$1,100
call or txt 0422140579
Edited by banhzSIIR33
FS:
Brand New Tomei Sump Baffle $280 rrp $399 at JJR
Used Tein Fixed Height Coilovers, Type HR to suit R32 GTR/GTS4 - $600 negotiable
Used Bilstein Fixed Height Coilovers, unsure what type but they handle very nicely. Slightly lower than the Teins. To suit R32 GTR/GTS4 - $600 negotiable
Used Toyo T1R Proxes with camber wear x4 to suit 16x8 stock gtr rim (225wide), $50 or a bottle of wild the sphincter of the universe
pics upon request
-D
$1,100
do you have a pic of them fitted?
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
