If you need something for your R34 that you can see in the pics let me know on 0402 902 759
R34 Neo Engine 104,000kms (Engines now out and ready to be collected)
Including basically everything you need to run it, minus turbo.
$1,900
Drivers and Passengers Seat - $300 for the pair or $170 each
Very light wear on the drivers seat as you can see in the pics, passengers has no wear
Rear Seat - $80
No marks, great condition
Speedo - $50
104,000kms
Factory R34 GT-T Floor Mats - $80
If you see a car part you need in the pic let me know. Shell is leaving on Monday!
Also have boot lining in great condition with all clips
wrecking a non turbo manual series 2 r33 silver in colour and also wrecking a r34 4door neo turbo auto
also r33 track only shell complete $1000 without type m kit or $1200 as is.
i always forget to check my pm's on here so text is the best way if your after something 0415 23 23 97 im in mansfield pk
some pics here http://nissansilvia....howtopic=488969
wrecking series 2 r33 non turbo manual eveything is silver in colour so if u need something thats not listed just ask.
4 stud 17inch rims with 85% tread $450 suit 4stud skylines and silvia's
r33 wine red type m kit, front bar with indicators and fog lights, side skirts and rear pods $350
wine red r33 track only shell has non turbo motor and auto box, car is straight $1000 with out the kit or $1200 as seen in pics.
complete motor and gear box anything you need from the engine bay , tail shaft, gear stick etc $1500 FIRM only has 117xxxkms
clutch slave as new $50
brake booster $50
type m side skirts $150
4 stud brakes complete $350
r33 lower control arms $100
s2 boot with spoiler $150
tail lights $80
rear bar with reo $100
stock exhaust with cannon muffler $100
complete boot carpet $60
tinted rear window $100
tinted side windows $50 each
tinted door glass $50 each
doors complete with glass, mirrors $100 each
s2 complete interior $250
dash cluster 117xxxkms $70
left hand front guard $100
WRECKING R34 4dr NEO TURBO AUTO
complete motor with auto box what ever you need....completely standared $2200 o.n.o
think it has the standard pop up tv will check a.s.a.p if so $150???
complete gtt brakes $600
4dr weather shelds $200
boot with gtt witg $150
rear lip kit $100
gtt interior, seats trims carpet etc $350 the lot
rear window glass $150
door glass $80 each
boot carpet $60
complete doors $150 each or $100 no glass
side mirrors $50 each
stock exhaust with after market muffler $150
if its not listed just ask i might have it....has no front end parts.
located in mansfield pk adelaide ..text only please i dont check my pms on here 0415 23 23 97
ay mate just enquiring about the silver 33 passanger door if you have it?
are you up for trade plus cash your way? i have 18x8 - 18x9 +35 Racinghart CX
Sorry mate, cash only. Does include good condition toyo 888's on the rear's, front have very old comp only tyre's that should be replaced. Can remove if prefer!
cheers
R32 GTR bits
Stock front upper arms - $40pr
Stock rear camber arms - $50pr
RB26 stock coilpacks + igniter. Condition unknown - $150 set (incl igniter)
3x sets RB26 exhaust manifolds. $100pr
R34 dump pipes (rear has a stuffed o2 sensor in it) - $80pr
R32 dump pipes - $50pr
R33 RB26 stock oil pump. Came off a healthy 65k motor, replaced with a Nitto -$100
RB shifter. Suits all RB boxes as im aware. Bit rusty - $30
RB flywheel. Needs a machine - $50
Stock R32 GTR turbos. One fine, one blown (missing exhaust wheel). Both with actuators (blown one has actuator off it in the photos) - $100pr
R32 stock merge pipe - $50
R32 Twin Turbo pipe, and some “hot side” pipework - $40 for the lot
R32 drivers side mirror, black. Came over in the boot of the car -$60
2.5” Side exit (race) exhaust pipe suit R32 GTR / GTST. Unbolt cat from front pipe, bolt this in place. Goes up and over rear cradle and exits downwards in front of rear wheel (even has threaded flange for exhaust temp sensor from the cat) - $50
Stock front and rear swaybars. Links okay, probably due some new rubbers - $65ea or $100pr
RB26 oil and water lines. Probably got a set and a bit of spares. $100 for the lot!
R32 GTR rear seat. Good condition (hard to get a good photo as its in storage in the shed - $150
R32 GTR Parcel shelf. No holes for child seat brackets - $80
R32 GTR rear inner trims (below window). Good condition - $80pr
R32 RB26 block. Not been stripped down, bottom end knock. 113k on the motor, will not be supplied with engine number. $250
R33 RB26 head. NOTE, PLENUM AND ITBs already sold. Head has no cams, rocker covers etc, has valves in it though. Came off a 65k R33 RB26. $350
Other bits
R31 Noltec Adjustable Panhard Rod - $90
R31 manual gearshift lower boot (rubber and metal trim) - $40
R31 clutch master cyl (minus lid), solid line and rubber line, clutch slave cylinder - $50 for the lot
R31 rear upper trailing arms. As is with nolathane bushes - $40pr
R31 front bumper indicators, okay condition - $10pr
R31 side indicators, okay condition - $10pr
Universal bullbar indicators (from TJM bar). Wires cut, but wont be hard to rewire - $15pr
GQ Patrol (early series) grille indicator / parker lenses. Hairline crack in one, otherwise works fine - $40pr
GQ Patrol (late series) body tail lights. Not modded for brake light, reverse lights work - $50pr
GQ Patrol ST wheel arch flares x4. Gold colour, scratched, couple of plastic tabs broken. Rubbers need replacing too. $50 for the lot
Contact via PM :)
  • Like 1
cheers
They aren't that old are they? half the 'new' track tyres you buy in aus are older build than 08.
I drove on them a few months ago and they still had a massive amount of grip - combined with GTR brakes on the S15 the car had the best stopping power and feel of any car I have driven in a long time.
2k is a very good price, without contacts you couldn't replace the tyres for that much
Edited by samstain
super lights 15inch rims for sale 4 stud
got a guy buying my car and he needs these gone before i get my cash.
15inch super lights i dont know the offset, they are multi 4 stud
they have 80-90% KUMO TIRES....looking for $1200 o.n.o rims are like new. FEEL FREE TO MAKE HIM A OFFER.
call 0450047726 located in wingfield......dont pm me they are not mine...cheers
pics here http://nissansilvia.com/forums/index.php?showtopic=489337
http://ajps.com.au/parts/performance_wheels.asp
Items:
1. 1993 R32 RB20DET OEM Motor (Short)
2. 1993 R32 RB20DET OEM 5 Speed Manual G/Box & Clutch
Item Condition:
1. Motor has standard internals and is in VERY GOOD condition. Regular servicing (5000 kM oil/filter change, yearly water change etc.). Has been relatively standard all its life until 2007 where it made 170 RWkW on the standard turbo. All that is required is a quick clean. Hydraulic lifters RARELY click on start up (if you leave the car for a week or two and start the car they will tick for about 1 second until the head sees oil pressure/flow).
Comes as a short motor i.e. intake/exhaust manifolds and related parts (associated piping/tubes), ancillaries (a/c, p/s etc.) are NOT INCLUDED. Included is the OEM turbo. If you need further clarification with what comes with this please either contact me or Google what a "short motor" includes.
2. Gearbox is a standard OEM 5 Speed manual from an RB20DET. No noises. No crunches. VERY GOOD condition. Oil changed with Castrol oil (Sydneykid's thread in Drivetrain section of this forum) every 20,000 kM. Comes with a Heavy duty clutch (unknown brand and type etc. until I pull it out in a week or two). Clutch has never slipped. Condition of this part will be know once I have removed them from the car.
Extra Info:
Items will be removed from the car in the coming weeks. More info will be updated as it becomes available as to the condition and type of parts removed.
I will accept deposits.
I MAY separate parts. However, this will depend on several circumstances.
Contact Details:
e-mail: [email protected]
mobile: 0401 317 009
PM me if required
Price and price conditions:
1. $500 ONO Will ship at buyers expense
2. $200 ONO Will ship at buyers expense
OR $600 ONO as a package deal. Will ship at buyers expense.
Edited by R32Abuser
Need to get rid of our "old" couch asap
As we just bought a new big mofo and have no
Room to store this one.
It's a 3 seater sofa plus chaise, so pretty much a 6 seat
Lounge suite. Purchased from Harvey Norman about two years
Ago and set us back $1500
Chocolate suede, good condition except for one broken wooden support on
The back of the chaise, I think someone got a bit too excited over the
Stripper at my bucks show :-/ lol
$100 firm can deliver locally free
Located northern suburbs
Needs to go asap.
0422200780
pics here http://nissansilvia....howtopic=489337
http://ajps.com.au/p...ance_wheels.asp
16INCH SUPERLITES
MULTI 4 STUD
CAPS AND MAG NUTS
6 OFF $1650 ONO
R33 SKYLINE ROLLER NO BRAKES OR ROTORS
$500
0450047726
FOR SALE :
$190
Original R34 Nismo/Altia Rear Bumper in silver, few chips and scratches, bought it and never put it on my car.
$50
Full set of R34 coil packs, all working and in excellent condition of 80,000km motor.
Take em both for $200
P.M for pictures, or contact me on 0415087363.
Clearing out the shed and selling my turbo to make way for something bigger and better.
Brakes, $500 for the lot;
All were in good working order when removed, BMC has been kept wet since removal, rear calipers will be basically useless for everyone, but pads and rotors are always handy. Won't separate unless you can find someone else to buy what you don't want/need.
S14 4 pot front calipers w/ all hardware & hard lines
S14 1 pot rear calipers w/ all hardware
RDA S14 slotted front rotors
RDA S14 slotted rear rotors
Nissan rotors to suit R33 (plain)
S14 BM44 NON-ABS
1 set Acre Street Fighter pads (front)
1 set QFM A1RM pads (front)
1 set Genuine Nissan pads (front)
1 set Silverline pads (front, unused)
1 set Bendix StreetRoadTrack (rear)
1 set QFM A1RM (rear)
(S14 front, requires machine, 29mm)
(S14 rear, good to go, 9mm)
(R33 front rotors, good to go, 29mm)
Tial MV-S 38mm external gate, with optional water cooling, brand new, only taken out of the box (which arrived today...) for photos. $400. Firm.
2860 Hi-flow, journal bearing, .64 rear, with HKS Hard intake, Comp cover, inlet, and outlet all powder coated in textured black. enlarged waste gate port (currently at MTQ being done), less than 10,000k's since rebuild. Never run above 1 bar.
$800 with HKS intake pipe, $600 without.
(Exhaust housing not pictured, will obviously be included).
Located in the Northern 'burbs.
Can be contacted on here or on 0408961657. SMS messages will likely be ignored.
Cheers!
Dave.
R32 GTR WHEELS WITH BRIDGESTONE RE0-1R SEMI SLICKS! Perfect for the track, get the hot and they'll stick like shit to a blanket. $850!
EDIT: ONLY PIC I HAVE THAT SHOWS THE TREAD OF THEM. As seen on Damo34's track hack
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
