s1/2 r33 rb25det head for sale, rebuilt 7000kms ago have receipts, motor has done rings so replacing it with a neo 6 and selling off the bits.
Head is very clean, turns over by hand fine, all valves look fine.
call Roland on <removed> or PM me on here.
F.S
R32 GTR 93
DEFECTED
NEEDS NEW TYRES, SIDE INDICATORS, HORN, WINDSCREEN WIPER RUBBER,
125XXX KM
260KWATW GOT DYNO SHEET
MINES COMPUTER & AIRFOW METRES.
CAR IS DEFECTED AND I DONT HAVE THE TIME OR MONEY TO GET IT OFF . I NEED THE CASH ASAP THIS IS WHY IM SELLING THE CAR CHEAPPPPPPPPP,
BODY IS STRAIGHT AND ENGINE COMPRESSION IS EXCELLENT, ANY CHECKS ON THE CAR IS WELCOMED. BODY IS A LIL ROUGH AS IT WAS A BACKYARD SPRAY JOB
FIRST WITH CASH GETS IT I AM NOT HOLDING IT FOR ANYONE, NEED TO SELL BY THIS WEEK.
8K FIRM
0468931301
F.S
R32 GTR 93
DEFECTED
125XXX KM
8K FIRM
0468931301
Ohh and you can't legally sell a defected car in SA.
you can but it needs to be sold as a wreck.. as you cant legally transfer rego into your name which means you dont "own" the vehicle.
i bought a defect car, then sold it, guy who bought it got caught speeding and as i could transfer it into my name the cops came after me, then i said i sold it so they went after him, but fined me for selling and buying it.
Contact: 0402 902 759
R34 Parts
Door cards $150
Turbo Back Exhaust , standard dump, 3" front, cat, 3" catback with cannon and 4" tip $450
R34 Passengers guard $150
R34 Rear Seat $80
Glove Box $50
Complete Boot Interior, Mat, Side panels, Black plastics $150
KYB Buzz Spec Suspension, damper adjustable $500
Front Reo $150
R34 Bonnet $300
Front strut brace $100
Rear parcel shelf $50
Dash + Airbag $200
Interior rear quater panels, Pair $100
ECU cover $30
R34 Brakes
Front and Rear
Calipers and Rotors
$650
Dash Cluster $80
Zenon Headlights pair $900
Front Lower Control Arms pair $175
Standard Intercooler $130
S13 SR20 Blacktop Power FC with hand controller. Can be converted to redtop S13 SR20. $850
GCG Highflow turbo $1000
R33 Diff $150
R32 Cat back exhaust $300
R32 Turbo $100
4x Bridgestone Playz 245/45/18 $150
17" x 7.5" +30 pair $50
S14/R33 Steering wheel $220
R32 GTS-T Steering Wheel
Apexi ECV $200
Boost Gauge $50
Steering wheel 80mm of "dish" $70
Nardi Wheel $220 Each
Steering wheel bought from Japan in late '08 $100
Nardi Wheel $220
Turbo time with loom from a 32
FIRENZA 245/40/18 pair $120
5 Stud none type M Wheels from R32 GTS-T, 2 with brilliant tyres, 2 are bald $150
Sparco Wheel x 4, All tyres are of no use, 17"X7.5 $150
Any 34 owners interested in a rear strut brace? I have this: http://www.justjap.com/store/product.php?productid=18327&cat=394&page=1
Its brand new, only test fitted by previous owner, then sat in my shed. Paid full retail for it, they are on special with JustJap for $75 + post, come and pick it up for $80!
R34 Parts
Door cards $150
R34 Rear Seat $80
Glove Box $50
Front Reo $150
R34 Bonnet $300
Dash + Airbag $200
ECU cover $30
R34 Brakes
Front and Rear
Calipers and Rotors
$650
Brings tears to my eyes seeing my old 34 in pieces :'( Any chance you have the speakers man??
Fund my rebuild peeps!
R33 GTR REAR strut brace, $130.
R33 GTR REAR swaybar, $60.
Standard R33 GTS-t swaybars - front and rear - $30 each.
PAIR of 5x114.3 rims, still plenty of meat on the tyres, white, 5-spoke, gutter rash but decent offset. Perfect for skidding. 17x8 I believe. $250
RB20DET reflashed to suit Series 2 RB25DET w/ 12psi, cooler and exhaust $120
Also EOI - Genuine Bride Zeta II on Genuine R33 Bride rail, worn on drivers side bolster but seat is still perfectly usable $450.
Edited by Bridgy
Hey, stripped the last of the R32 (2dr). All these bits are $5 each. Come get em or they're goin to the dump. :)
All gotta go
Msg anytime: 0421666324
Sam
Is that the entire boot trim?
Anyone want my AIM Mychron Light lap timer.
Bought it second hand about 12 months ago and haven't used it but since i don;t have a running car at the moment it's probably more important that i get my car running than have a $300 lap timer sitting on my shelf.
Price $300
Cost me $350
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
