- r33 gtst Rubber intake pipe with oil breather apparatus $35
- r33 gtst Stock dump pipe $20
- r33 gtst Stock dump & front pipe $30
- r33 gtst Oxygen sensor $40
- r33 gtst Air Con fan $35
- r33 gtst Stock Intercooler + Pipes $65
- r33 gtst Series 2 coil pack loom $40
- r33 gtst Alternator $60
- r33 gtst 2nd hand water pump works fine $35
- r33 gtst Timing belt $30
- r33 gtst Bosch Air con, power steering, alternator belts brand new $70
- Garrett Adjustable Actuator with bracket 15psi ( New) $70
post-31991-0-00191800-1312509850_thumb.jpgpost-31991-0-47424700-1312510002_thumb.jpgpost-31991-0-65943700-1312510039_thumb.jpgpost-31991-0-40924900-1312510062_thumb.jpgpost-31991-0-23302700-1312510069_thumb.jpgpost-31991-0-69927800-1312510096_thumb.jpgpost-31991-0-38416300-1312510119_thumb.jpg
EOI: 17x9(i think, might be 8's) Drift R rims, 5x114.3 full set, near new tyres on rear and ok condition tyres on front. Slight gutter rash, good condition otheriwse. $800 ono.
R33 plazmaman intake plenum.
Comes with plenum, bottom half to head, vacume fittings. All you need is to bolt your throttle body onto it and your idle control valve.
$950
Rb25 hiflow 740cc injectors. Run 380rwkw
Come with rail
$450
$950
Come with rail
$450
OK... is there a adjusted price if both are taken and if you have flow results for the injectors and have they have been run together(plenum+rail+injectors)? Plus receipts for the plenum, etc? Basically a EOI from me ATM.(no guarantee's)
(looking to change my setup soon and these kind of things will be needed, post pics if you have them)
Cheers,
Shannon
Hey Shannon.
Can arrange a package.
I'm in Sydney atm so no pics.
I don't have the reciept but I bought the manifold new and its painted black.
The injectors I got hiflowed from a member on here. The have been flowing good numbers for a year now.
Txt me. 0433290801
For Sale.
Set of excellent condition G4 Racing coilovers for R33 GTR, anodised blue in colour, bought these for my z32 as was told that they would fit, rears dont so there up for sale
chasing $700 firm
also comes with 2 Laser cut 5mm steel C-spanners i had made at work.
PM or Sms on 0424521315.
pics via sms
Bump.
180SX
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32 CLUTCH SLAVE
R33 STEARING COLLUM
PLz pm offer on anything u need dont have time to go throught it all and find out what its worth
cheers
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $10ono
2: HKS Boost guage and loom (60mm) $40ono
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $40ono
4: 2x 5 stud 15mm Hubcentric Bolt On Spacers $100 FIRM - Need to sell spacers ASAP
5: R32 2door L&R boot trim $5 each (Has holes cut out for strut brace)
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
Few parts bits and pieces:
RB25 POWER FC, with hand controller: $1150
LEFT TO RIGHT:
R32 $120
R34 $250
R32 $120
S13/180sx $120
R32 $120
JUN Front bumper $100
JUN Sideskirts $100
are those side skirts for the R34 GTT?
fs
r31 silouette shell roling wired for rb25det
front coilovers
rear is aftermarket shocks and springs very stiff
boost and temp guage sparco
new 2.5 " exaust system
s13 lcas
s13 knuckles
Garage 7 tie rod ends
Lock spacers
huge front sway bar
all bushes been replaed withn noalthane
all lights work
sr20det front brakes
new pads and rotors allround calipers rebuilt
freshly shimmed diff comes wit spare wellded centre and axels
no plates track only.
built for missus she slid once at drift school did great job i have also slid this car and handled awesome very easy to steer very good car for a grass roots drifter had no troubles with it
1800 ono only missing engine and trans sold on 31 silouete stockys
Thrust bearing to suit pull type clutch for GT-R
Bought it the other day from Just Jap, only to realize I had one supplied with my replacement clutch..
$50 if someone wants it, I can bring to dyno day this weekend if not I'll use it for my next clutch haha
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
