still have 4 18''x8 lenso wide track rims for sale 2 in perfect condition 2 need to be re rolled due too buying them already like that,
offset= 40
comes with 4 225/40 tires in near new condition if i remember correctly.
just sittin in the garage $200
R33 gtst Parts for Sa
- Stock dump pipe $15
- Stock dump & front pipe $20
- Oxygen sensor $35
- Air Con fan $30
- Stock Intercooler + Pipes $60
- Alternator $50
- 2nd hand water pump works fine $30
- Timing belt $25
- Bosch Air con, power steering, alternator belts brand new $70
- r32 rb20det & R33 rb25det exhaust manifold gasket kit new $65
Cheers
Neo AFM - $50 - SOLD pending payment
C34 stagea lhs front fender - $100
6 coilpacks, condition unknown - $50 - SOLD
Neo engine cover - $50
RB25DET valley/coilpack cover - $25 - SOLD
Discovered I have:
another RB25DET valley/coilpack cover - $25
R33 airbox - $25
Stagea series 2 grille - $25
R33 series 1 indicators - $25
New/unused non-bosch Z32 AFM - $100
RB25DET bov - $25
PM me
Got these to clear
R33 s1 AFM - $50
q45 AFM - $100
R33 s2 plastic skirts, need a bit of repair on side mounts (crack) and tlc - $40
r33 a/c condenser core - $50
r33 std. sway bars front and rear - 6 pack Super Drys or $10 ea
Edited by SkyHi_33
R33 GTS-T
Has:
Full Body/suspension
16in wheels
3in exhaust (if not sold beforehand)
No interior but has dash, speedo steering wheel etc
Drivetrain except gearbox an tailshaft
Motor but needs rebuild
Price: $1500 take it away!!! Want it sold THIS WEEKEND!!!
Also
R33 s1 AFM $50
R33 s2 AFM $50
R33 catback 3in $100
R33 stock turbo blown exhaust wheel $50
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400
Sard FPR $80 - SOLD
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
For sale.
R33 S1 Dash 100$ - Has 3 screw holes on the passenger side as seen in picture.
10 000k HID Kit - Used for a few months but working fine - 50$ (Blue light) SOLD
Cusco Strut Brace - Type OS (New but with some scratches) - 100$
R33 and 5x114.3 super happy bargain Sale
17x9 +17 Work equips w/ centrecaps. little bit of rash and paint flaking off, but for the price you cant complain., stop fitting fake wheels and running gay widths and offsets, buy some proper Jap 2 piece wheels for the same money. 2 have no tyres, 2 have Maxxis 235/45r17 about 4mm above markers.
$1100
4x Falken ZE912 tyres. 235/45 r17 $120 each, 95% new, done under 1000kms, can do for $400 if you buy all four
R33 3" Jap cat back exhaust with a cannon $100
3" Magic Cat high flow cat, suit r33 or change the flanges to suit anything $50
r33 / 34 GTR 324mm rotors suit brembo. were just freshly machined. just RDA standard rotors. are $246ea new, 30mm new, currently have 28.9mm, min is 28mm. so just over half worn. $150 for the pair
Cusco front and rear strut braces $100 each
thanks
0411742212
JVC KW-AVX710 In-Car double DIN touchscreen DVD player
as new condition - everything works 100% - includes box and everything that comes standard
$400
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=133&modelId=MODL028304
EOI: 17" Drift R rims pending fitment of new wheels, 2x maxxis mav-1's currently on rear, pretty much brand new, been on for a few weeks and a pair of camber worn blue streaks currently on fronts. In good condition, few usual gutter marks. $700
Hey
Got a couple audio parts for sale. All parts work extremely well and have no scratches or knocks, they all look like new.
Pioneer GM-6200F 4ch x 60rms or 2 x 150rms $150.
Pioneer GM-D8400M mono block 1x300rms @ 4ohm or 1x600rms @ 2ohm. Has remote sub level controller $250.
Cheers
Edited by slippylotion
R33 GTS-T
Has:
16in wheels
No interior
Price: $1500 take it away!!! Want it sold THIS WEEK!!!
Also
R33 s1 AFM $50
R33 s2 AFM $50
R33 rear lights 100
R33 S2 rear garnish 50
r33 radiator $100
HKS SPF Pod $100
Clutch fan $40
Thermo fan $40
r33 turbo $100
R33 Airbag s1 GTR wheel $250
r33 gtr speedo 61k $400
Exedy heavy duty clutch needs new friction plate $100
S1 R33 coils $60
Many other lil bits an pieces too PM me what you want.
Few RB25 parts left over from a recent engine swap, they're all from a S2 engine.
CAS - $50
new headgasket $80
new exhaust manifold to head gasket $40
injectors and rail $70
injector loom $40
throttle body with tps $40
25det block (water/oil/sensors still attached) - 2 pistons damaged $150
Adjustable FPR $60 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
PM Enquiries..
pair of Federal 595 RSRs 235/45r17, used as steer tyres for one mallala day. heaps of tread, stored inside. only selling a pair due to having several and could use the coin
$250obo
can mms pics if you need
0411742212
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
