FS- sard FPR with pressure gauge.
bought the wrong one, needed the bigger one :(
its red, brand new.
i paid $225 for it.
need to sell it at a loss to get a new one to support my fuel system :(
$150 for quick sale. can mms pics.
For Sale:
11yo thoroughbred horse (mare).
Beautiful horse thats been vaccinated, wormed and shoed. Come with saddle, rugs, halter and lead. Currently stabled at Globe Derby. Thoroughbreds of this age generally seel for around $1.5K-2K.
Not suitable for beginners.
$1,000 firm
:thumbsup:
For Sale:
$1,000 firm
:thumbsup:
Time to get rid of the mrs ay? :rofl2:
FS - R33 GTR carbon fibre grill
brand new, bought it because i was going to put a gtr front end on my gtst , changed plans and went to a series 2 front so went with a different grill. bought it for 200 about 2 months ago.
$160 or make us an offer. need the cash to pay for other parts!
i do also have a nismo steering wheel and a veilside bodykit in stock 33 gtst burgundy colour. front end is damaged but skirts and rear pods are perfectly fine!
pm for info/pics/price or
text msg 0421549607, cant answer calls at work.
20x8.5 starcorp kaotic rims,with tyres round 80% unsure of offset 5x114.3
Basically brand new wheels,got them on my hilux i bought.not my cuppa tea so im selling
Barely a mark on them
Can include 1 pair of 25mm spacers for extra
$650 without spacers
$700 with spacers
Sms me for pics as ive only got iphone internet access
0421754575
1 pair of random 18x8 4x114.3,canned black,with tyres round 50%
Good skid wheels,had them on the laurel,now just taking up room
$100
Rb20 turbo ( has actuator and lines )80 bucks
Greddy sandwich plate and sensor 50 bucks
rb20 injectors 60 bucks
I need a passenger side r33 lca, so can work out a deal if you need any of those things.
Cheers
Cheers
how much just for the rb20 actuator??
Items:
Hankook RS3 265x35R18 (x4).
Item Condition:
Brand New.
Extra Info:
Surplus from Superlap, and I don't own any 18s to use them myself post event. Locally approximately $395 per tyre. Very impressed with the grip of these tyres on a racetrack. Fantastic high performance street tyre. These are the tyres you want for Superlap clubsprint class. Available now.
Contact Details:
Via PM is fine.
Price and price conditions:
$1,100 FIRM. Pickup - Cash, EFT, etc.
R33_GTRV, on 17 August 2011 - 09:43 AM, said:
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500 ONO
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$ ONO
Cheers
PM sent.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
