Hi guys,
I've got 2 sets of front 33 rotors (5 stud).
One set has heavy surface rust, very bumpy and are rather worn - $20
The second pair are in good nick, very small outer lip and could be used with just a light sand - $65
PM enquiries!
Hey Guys,
Looking to sell the below wheels / tyres.
The wheels have some gutter rash on them. 19", come with spacers as they are 5x 120 so not standard for Skylines.
Uncertain about offset etc, but they barely fit in the GTR.
2 Tyres are good, almost new.
2 Tyres are shocking as they have been grinded back by previous owner.
Looking for 400$ inc spacers
Pickup required.
Thanks,
Adrian
Price drop on following items.
Sard 600cc injectors $400 (suit RB26, uncertain if these will fit on rb25 fuel-rail so if somebody knows this it would be really helpfull)
Apexi Power FC with hand controller 800$ (suit R32/R33 RB26DETT)
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting(plastic) $150
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $50
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
catco high flow cat 2.5inch 325mm long $50
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
R33 rb25det charcol canister $20
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics (page 4) is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
pm me or sms 0435 888 239
Will post at buyers expense
Dave
Hi guys
up for sale is my black Velo gp90 racing seat. The seat has been used for approximately 1 year. It is in immaculate condition, it comes with rails to suit r32 Skyline and Rear parcel shelf harness mount bracket which fits in place of the rear drivers side speaker all included. $600ono contact Ben on 0421675373
Pair of Recaro SP3's in excellent condition, dark grey/black with red insert $450 ono
4x Adavan 032R semis 205/60/15 $350 ono
Dont get on here much, so best to message or call on 0413697162
R33 gtr speedo 62k. Price. $200
R33 s2/r34 AFM. $ 50
Genuine R33 S1 Bomex front bar $100
R33 Radiator. $100
R33 Clutch fan. $ 40
R33 Thermo fan. $ 40
Doors an windows. $250
R33 s2 Rear Garnish $ 20
R33 gearknob. $ 20
R33 Ashtray. $ 20
R33.Indicator stalk. $ 40
R33 Washer stalk. $ 40
R33 s1 Dash. $100
R33 gtr airbag Steering wheel. $150
S1. R33 dash an engine Looms $100
R33 ignition barrel an key. $120
S1 r33 interior. $150
wrecking almost complete 4 door 32
180SX
Mint 180sx door trims.
centre dash console
some small random carpet bits
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
180sx sunroof cut
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
CLUTCH SLAVE
door bn kit brand new minus front bar $250
2 door bn sideskirts good nic $100
r32 gtr roof lining
32 gtr roof cut
R33 STEARING COLLUM
Also wrecking a complete r32 gts4 minus motor trans couple lil bits
I have few more 180 bits then above let me know what u want and make offer need it all gorne
Pick up from barossa valley sa
Pm here or
email [email protected]
cheers
Edited by Ke55pig
Selling my daily, AU series 2 supercab ute
-250,000 k's
-Dedicated gas
-Super reliable
-Great stereo system
-Sports exhaust
-Colour coded canopy with heavy duty roof racks worth over $2k..
Used daily as a work ute and been great. Will tow pretty much anything up to a car. Large dent behind drivers side door, needs a new quarter panel.
$4500
PM me if you're interested!
Joel.
180SX
centre dash console
HANDBRAKE COVER $15
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH WIPERS
BRAKE BOSSTER
L&RH PILLAR TRIM
CA LOOM
CHAROOL CANISTER
180sx sunroof cut
R34
AUTO CONVERTER $50
R32
CLUTCH SLAVE
r32 gtr roof lining
32 gtr roof cut
R33 STEARING COLLUM
Pm here or
cheers
How much for the 32 headlight switch and plug?
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
