2x sparco evo 2 plus seats (unused) - $900 or $500ea
I picked them up couple years ago as an impulse buy, not sure if they're genuine or not which reflects the price, they have a sparco sticker on the side, all the plastic harness inserts are stamped sparco and theyre very sturdy n comfy. Been sitting around collecting dust, I might as well move em on.
1x Bride drivers side rail fit r33 - $150
One sparco seat and rail sold,
1x sparco evo 2 plus seat avail $500ono brand new.
FS
Whiteline KTA128 Rear adjustable camber arms - USED
Compatible with:
Nissan 200SX S14, S15(7/94-02), Nissan SILVIA S14, S15(7/94-02), Nissan SKYLINE R33 GTS, GTS-T 2WD(1/93-12/98), Nissan SKYLINE R33 GTR AWD(1/93-12/98), Nissan SKYLINE R34 GTS, GTS-T 2WD(11/98-02), Nissan SKYLINE R34 GTR AWD(11/98-02)
$250+shipping (or buyer picks up). RRP $363 new.
-D
ALL PRICES ARE AS PAIRS
15"
2x 195/50 - Firestone Firehawk - 60% tread - $70
2x 195/55 - Federal 595 - 80% tread - $90
16"
2x 205/55 - Michelin Pilot Preceda - 60% tread - $80
17"
2x 205/50 - Bridgestone Potenza Adrenaline RE001 - 60-70% tread - $90
2x 215/45 - Pirelli Dragon - 60-70% tread - $90
2x 225/45 - Continental SportContact II SSR - 80% tread - $110
2x 225/45 - Bridgestone Potenza RE050 - 50% tread - $60
2x 225/45 - Pirelli Pzero Rosso - 60% tread - $80
2x 225/45 - Sumitomo Z3/Potenza RE001 (mismatched) - 70% tread - $80
2x 225/45 - Goodyear F1/Dunlop Sport Maxx (mismatched) - 70-80% tread - $90
2x 235/45 - Bridgestone Potenza Adrenaline RE001 - 70% tread - $100
2x 235/45 - Dunlop/Triangle (mismatched pair) - 60% tread - $70
2x 245/40 - Bridgestone Potenza Adrenaline RE001 - 70% tread - $100
2x 245/40 - Kuhmo/Nankang - 60% tread - $70
2x 245/45 - Firestone Firehawk - 70% tread - $90
2x 245/45 - Pirelli P7 - 60-70% tread - $80
2x 255/40 - Michelin/Bridgestone - 60% tread - $70
18"
2x 215/45 - Yokohama/Federal (mismatched) - 60% tread - $70
2x 225/40 - Sumitomo/Nankang (mismatched) - 60-70% tread - $70
2x 235/40 - Dunlop/Continental (mismatched) - 60-80% tread - $80
2x 235/40 - Rotala/Dunlop - 80-90% tread (drift only) - $80
2x 245/40 - Dunlop Sport Maxx - 60-70% tread - $90
2x 245/40 - Toyo Proxes 4 - 60% tread (with slight outer wear on 1 tyre) - $70
2x 245/45 - Bridgestone/Dunlop (mismatched pair - sidewall damage in 1) - 60-70% tread - $60
19"
2x 255/30 - Advan Neova AD08 - 60% tread - $110
Located near Mitcham in SA
15"
16"
17"
18"
19"
Why are they drift only?
R34 OP6 Neo Turbo
Minimal to no shaft play,boosts fine no smoke
Came off motor with 110k on odo
Has oil drain attached and the elbow
Can come with the oil feed and water lines
$380 neg
Stock turbo manifold off same car,comes with the gaskets
$30
Or both for $400
Only selling as im doing upgrades atm and have a b/new td06h to go on and a new manifold.
Located in Clearview S.A.
PM here or TXT 0432 838 323
Price drop,want this gone before the weekend
Turbo $300 FIRM
Manifold $20
R33 Nissan Skyline GTST 1993 5 speed
I have had this car for the past 4 years and it has never skipped a beat. It is the Ultimate Sleeper.
Complete HKS Hi-Power exhaust system turbo back cat back, Sounds awesome!
HKS 2530 turbo!!
HKS FMIC and HKS Mushroom pod
Yellow Jacket Coil Packs
Exedy Racing Clutch
Very nice sound system, Alpine mono amp and 12in Pioneer sub, full tweeter setup Plus much more we can discuss upon contact
It has been serviced every 5,000kms since I've had it with Motul fully synthetic oil.
Ive lost my job so need the cash.
$7100 FIRM
17x8 Drift R's for sale.
Good condition
Good tyres, only fitted a few months ago, 2x sumitomo zII & 1x Maxxis MA-V1 & 1 random due to puncture in other maxxis
Some gutter rash but overall good condition
After $550.
Just an EOI at this stage. I wouldn't mind replacing them with a set of 18's, but I love these wheels, and am in absolutely no rush to sell.
17x9 +18 with 225/45 Kumho KU36 with 70%ish tread, and 17x10 +20 with brand new 255/40 Federal SS595.
They were recently stripped back to bare metal and professionally painted in metallic silver, come complete with centre caps.
As usual with painted wheels, some paint has been stripped off the bolt holes by the wheel nuts, but it's only evident when you remove the wheel. There is some light guttering on one of the wheels, but again, it isn't really noticeable. I'll get pics of both up in time.
Very lightweight wheels, comparable to TE's. Plenty of caliper clearance, and they look tough on just about anything.
If you want more pics, just ask.
As for price... Taking offers above 3k. And again, I am in absolutely no rush to sell these. And unless you have something pretty special to offer, I'm not interested in trades.
Contact via PM.
Cheers!
1. Drift gauges They are boost A/F and oil pressure. $80 SOLD pending payment
2. Rear subframe non hicas. r32/33 great if you want to swap over and not have hicas. Great condition. $100 SOLD pending payment
3. rb 20det broken gearbox. 1st and 2nd didn't work $50 SOLD
4. R33 GTR V spec AC condenser $50
5. R33 GTST AC condenser $50
6. R33 boost solenoid $50
7. R33 wiper Amplifier. Great if your wipers don't return to start. $20
8. R33 climate control. $50
Phone Brad 0427999093 located near Golden Grove
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
