AutoMeter silver face pro comp mechanical boost gauge (66.7mm).
Given to me by a mate & never installed, sitting in its original box.
$60 (gauge only, no vacuum line, t pieces or mounting bits are included)
PM if interested
cheers
got some stuff for sale guys as my gearbox is on the verge of death now, so trying to free up some dollars for that.
Just jap dump pipe, suits R34. bought last week and has been on the car for all of 3 days. has just gotten that slight golden tinge stainless goes when hot. - $180
Just jap decat w/ gaskets, suits R34. - $50
Pioneer DEH-1350MPG stereo, bought to get the aussie station realised ive never really used it. comes with nissan -> iso -> pioneer wiring so no cutting/soldering required, can also throw in din pocket - $120 ono
Trust gearknob, not a scratch on it, just sits ontop of my busted gearbox :/ - $40 ono
Turbotech manual boost controller, was fitted for about a week until i swapped it out for an rb20 actuator - $25
and the LEFT weathershield from my 34 2 door, comes with all clips - $15 ono
can be contacted on 0433 987 945 or by pm
cheers ben
Anyone want a bent (looks like a failed flare job) RHF R32 GTR guard in Gunmetal Grey for $30ono, guard is bent due to having the wheel fall of the car and get cought in the guard before it flew out. My step dad wants it gone as it's taking up room in the shed. The wheel in the picture is an 18X8.5 unsure offest. PM or txt on 0433 522 234
hey guys up for sale i have a mint r32 series 2 steering wheel never seen another one like it its got a leather horn button unlike the usual standard one with the clear plastic coated one $150 firm pm me or text me on if interested 0421675373
cheers BEN.
pics upon request via text cheers
Edited by BENDERS32
cheers BEN.
then its not series 2
and that actually does make a big diff - the hicas magnets/sensor points are located in different positions. I was scratching my head for months till someone here told me about it. swapped the boss kit I had with a stock wheel and magically, I had hicas.
Cool story eh?
-D
Cool story eh?
-D
R34.
1998.
Turbo, Manual.
106k clock.
Blitz cooler,
Power FC,
Blitz EBC 14 pound.
Oil Cooler,
HKS pod.
exhaust
17" Jap wheels.
Welded diff, which some ppl take a while to get used to.
Only ever driven to work, never on cruises or circuits etc.
Bit of a waste in me owning, Really after a decent 4x4 with lift kit etc.
Just serviced, Oil, New belts, New brake pads
15k Firm. Cheap.
cheers ben
Do you kno if that decat pipe would fit on a r33 ? if so ill take it
For sale Brother MFC 9210. Home office printer. In excellent condition was a $1000 new selling for $250. Great for someone starting up a home office or allready has one.
Phone Brad 0427999093. Located near Parafield airport
Got a Brand new car entertainment/navigation system, bought it a week ago, arrived today however doesnt fit in my toyota dash (screen too wide) :(
Specs:
2-Din 6.2-Inch TFT LCD Touch Screen HD digital panel ( 800*480)
USB AND SD Interface
Compatible With DivX/DVD/VCD/CD/CD-R,RW/MP3/MP4
Built-in Digital TV Tuner
Built-in AM/FM Stereo Receiver
BUILT-IN GPS navigation
BLUETOOTH
IPOD ready
Radio With 18FM & 12AM Pres
Sowx4 Max
Rear Monitor video output
TFI high definnition IN-Dash LCD
Full function remote control
Automatic PAL/NTSC,wide application range,highly compatiable.
Few video inputs/outputs
Paid $450, yours for $400 need it gone asap.
comes with everything, gps antenna, ipod cable, usb cable etc. Still in box, only inspected and measured.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
