RB25 Standard Turbo $300
minimal shaft play, worked fine when pulled off car, held boost, no noises, clean exhaust.
RB25 Standard Turbo Manifold $75
Good condition, not warped.
RB25 Standard Front pipe $75
good condition, has O2 sensor
Kicker 400wrms mono block amp, $150
good condition
MTX Jackhammer subwoofer, 1000w peak, 250wms 12" in ported box $100
good condition, rated at 87db
Open to offers!
**cash only**
For sale: Dismantled RB20DET, currently sits as bare black on stand with everything else in box's. Engine is missing turbo, exhaust manifold, engine ECU, throttle body, knock sensors. Bores are in great condition.
Reason for sale: Bought a GTR so no longer need the engine.
Price: $300 until June long weekend. PM or txt on 0433 522 234
300$ Ono rb25 turbo mint condition no play come
Complete with actuator n snout to suit rb20.
250$ am performance screamer to suit rb, strait
Bolt on sounds sik gets bitches n shit.
200$ R32 m spec seats full set front n rear
0435163144 no pm won't get checked text only when ever
Work VS-XX Wheels - $3200
18x10 +13 - kumho KU36 tyres
18x12 -4 - Bridgestone tyres
Freshly polished and will have centers re-powder coated
RB25DET s1 motor, compression 145-160 on all 6 cylinders - $1300 ono
Comes with: Ecu, engine loom, ex manifold, alternator, ps pump, all belts and pulleys, YJ coilpacks
Does not come with: Intake manifold, injectors, injector loom
I do have a std intake manifold I can throw in for free however has no sensors.
RB25DET Manual conversion kit - $1800 or gearbox alone $1400
R33 s2 RB25DET Manual Gearbox (85,000kms)
Short Shifter
Slave Cylinder
Clutch Fork
Gearbox Crossmember
Manual Clutch and Brake Pedals
Clutch Master Cylinder
Manual Tailshaft (2dr)
Speed Sensor
Steel Braded and ADR Approved (HEL) Master to Slave clutch Line
Drivers side Gearbox loom to run manual transmission on automatic
Rubber Floor Boot
Interior Shifter surround console with leather boot
Exedy HD clutch (worn but will get you going)
RB20/25 flywheel
AM Performance split system exhaust - $1000
Decat to twin 2.5" system all the way to twin 4" pipes from diff back with titanium tips Suit GTS GTST GTR
Sparco sprint (blue) + R32/R33/A31 drivers rail 2 months old $650
Sparco Evo 2 Plus seat, no rails, brand new $650
R33 5bolt R200 diff, shimmed tight as $200
R33 s2 dash surround with vents, buttons and clock, mint $100
R33 s2 door trims with switches, mint $150
R33 s1 headlights, pair $350
Negotiable on most parts, need them gone yesterday. PM or SMS/CALL 0422 314 938
Also,
Selling the daily :)
1997 Model JZX100 Chaser Tourer V
Automatic
78,000kms
White in color
Full optional Toyota lip kit
HKS Silent cat back exhaust system (Fantastic 1jz tone without being loud!)
RSR suspension
18" Jap wheels
Lowest legal tint all round
De-badged
Just serviced and dynoed at 178rwkw
Clean inside and out, a beautiful drive!
Serious buyers please! Selling due to wanting an upgrade :)
Will consider swaps for evo 7/8, wrx sti and audi with cash adjustment upon negotiation!
PM or call/sms 0422 314 938
http://www.carsales.com.au/private/details/toyota-chaser-1997-12715342?base=1216&vertical=Car&Range=Price:Min,Max~0.5&page=1&eapi=2&sort=~Price&cr=5&__N=1246%201247%201252%201282%201216&silo=Stock&find=jzx100|CarAll
Stock parts from my R34 GTT
Doing upgrades and this stuff is no longer needed any more.
Radiator (no shroud) few bent fins,nothing major.
$80
Neo "Turtle Shell" Has been trimmed to allow for FMIC crossover pipe to fit.
$20
Neo crossover pipe.
$20
Neo ReCirc Valve (BOV).
$20
Neo Throttle body w/TCS unit (No TPS).
$40
Rb25det S2 TPS.
$30
Pink Label AFM. Excellent condition (will have plug for it when I wire up for my z32)
$60 or $80inc Plug
Stock Boost Solenoid.
$30
Stock Exhaust manifold.
$40
All Prices are ONO. Discounts for people that take multiple items.
Pick-up from Clearview 5085
Contact: Daniel 0432 838 323
Kr4 Silver R33 Series 2 bonnet. Has a small dent and a couple of small stone chips, otherwise in good condition. In Aldgate, SA but happy to freight if buyer organises and at buyers expense.
Price: $150
Contact: 0448 494 202
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash3/p480x480/554828_3875397161923_1188513835_3557659_1298648386_n.jpg
F/S Hi-Flowed RB25 Turbo. Minimal shaft play, running standard boost.
$300
How much power did you get from the turbo and how much use has it had?
Interested
Up for sale is a GCG gt3582 based turbo, would love to use it on my rb25 but it's way too large for drifting duties.
It is a GCG 3566R which is made with all garret parts to GCG specs. Its rated at 750 - 800hp so it will easily make 300kw at the wheels on any car with the right mods with the potential to make well into the high 400's Turbo does have oil and water fittings but no lines as i never got the chance to get them made. It is in great condition with no shaft play or damage
Included is;
GCG 3566R Turbo
One Piece Front/Dump Pipe and Cat
Ball Bearing
Oil & Water Cooled
Externally Wastegated
T3 flange
0.70a/r Compressor Housing
4" Compressor Inlet
2.5" Compressor Outlet
0.82 Exhaust housing
$1000 firm
Give me a buzz on 0431 836 94O
Check out GCG's site for more info
http://gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=335&category_id=34&option=com_virtuemart&Itemid=53
For Sale: Fibreglass R32 gtst Type B front bar from Viva Garage. No longer have the car it was going on so no need for the bar. Looks just like an R33 GTR front bar. Bar is not painted.
Price: $200 if sold before June Long Weekend after that it will be $250. At $200 i'm loosing money.
Located South of Adelaide. PM or txt on 0433 522 234
still on the car but will be off soon
injectors to suite rb20 turbo can be made to suite silvias or gtsts etc..
nismo 600cc injectors purple ones - $350
2860RS disco potato turbo done less than 1000ks - $1250
32 GTR cams - offer ?
R33 s2 i think drivers side door was white now in primer plus s2 door cards for both sides - offer ?
ESP left handed guitar and massive amp , pedals, stand, leads etc - $1200
home gym set up - $350
PM or text 0421549607 for pics and more info on anything. cheers
Hey guys have a few 2 way KAAZ diffs here, both have the same 4.36 ratio centres with S13/R32 housings, but 1 comes in a housing with 5 bolts half shafts, and the other comes in a housing with 6 bolt half shafts.
chasing $750
located near mitcham in SA, can post anywhere in Aus.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
