No, but you do have the same part (dashboard) as cars that do have TC and you have the same globe test wiring as everyone else. The lights all light up, not under the control of their various ECUs, but by a simple circuit that puts power on all of them with the ignition on and nothing else running. It's so you can see if the globe is working or not.
By TC light you mean "slip" light I'm thinking?
GTSBoy is correct, it's there so that Nissan could unify dashboard diagnostic and indication circuitry. It's meaning as an indicator is different depending on model though - on GT-t's it blinks when traction control kicks in, on GT Fours it blinks when TCU detects inequality of wheel speeds and engages ATTESA.
Your cluster was probably replaced with one from a car that had traction control. From factory the bulbs would be removed if the car didn't have TC.
this makes sense but im almost certain it hasn't been changed, previous owner possibly replaced leds in the dash and added that one back in again
and not its not the slip light as i have that also
but yeah i was just curious as to why it would be there still if there is no TC on all N/A models which have a different cluster with out the turbo made up for them anyway youd think they'd take the TC light out too
You can switch it off and unplug it but of you still rip the hand brake hard and flick it right out it will still come. Find the fuse and pull it out but light mite Tay on
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
