lol fair enough!!
back on the topic, whoever suggested the audi wagon, good luck with the understeer :P
i have to admit they dont handle too badly for a car with an engine in front of the front axel
  • Like 1
More of a hatch then a wagon if you ask me
Neither, its actually a "shooting brake" (proper name for a 2 door wagon)
And its not the first ferrari wagon either - Pinninfarinna made a wagon based on the 456 for the sultan of brunei
i just remembered this, they made this to beat the RS6, the ABT tuned RS6....
they also now created a RR hurricane M5 limited to 370km/h for safety, but as much as i know only one guy has put that racing package into his Touring.
but id buy this over ferrari anyday :)
G-Power M5
If I had enough money to buy that Ferrari I 'd get an Audi RS6 wagon ( the old one - they go for about $40K now) and put some new turbos and suspension in it and also get a new GTR. (But I haven't :( )
lol fair enough!!
there's a cure for understeer;
http://www.youtube.com/watch?v=LyyFi4puQ7s
RS2 Kills 2 birds with one stone, Porsche + Audi ownership as well
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
