ID2000 because of the volume of fuel at high rpm will not atomize properly, by having it further away from the intake valve you allow the fuel/air mixture more time to mix properly and enter the chamber. Proven that is makes more power at higher rpm having the injectors further away.
We will have both blanks running under full load and both banks running full sequential.
Yes if it was me id just run the one injector ie ID2000's. Well i remember about 2 years ago when i said to John can we just run the one injector,one large one. John went into great detail and expained injector frequency can run one cycle out of phase im not sure what that means and he said this is why we run two bank to cover up the out of phase injector.
I guess whats in Johns head is a greater understand in full detail how this whole buid is going to work.
Spray pattern is extremly important Vs Fuel Pressure you can bump fuel pressure and have the injectors spray like a hose in full liquid form, this is a mistake made by many people. This can lead to detenation caused by bad air fuel mixing.
A big high flowing injector will not atomise the fuel very well, hence placing it further away from the intake port will increase atmosation as it travels to the inlet valve... try putting an injector at 90°to the port and see how you go!
Wouldnt poor atomisation be caused by using the incorrect spray pattern and fuel pressure?? Especially in a boosted application?? I understand that a larger injector would be harder to get perfect atomisiation. but if its the correct injector with the correct spray pattern for the application, setup at the correct pressure wouldnt the angle of the injector cause minimal issues with atomisation?? Could you expand on it a little?? Sorry for the off topic chatter bobby.
Think about where they place injectors in F1... right outside the trumpet of the inlet parallel to the inlet port.
Thats all well and good but it doesnt answer my question. I understand that where F1 cars have them is ideal placement. But in real cars u cant always have ideal placement. Ive seen some old collectable cars with efi conversions that had the injector hidden under the manifold. The injectors would have been mounted at a 90deg angle at the least. Obviously a high performance application will be different, But im trying to understand more of the science behind it.
I was at John's Workshop and I found some paper work related to the build. Its very interesting how much details John has gone into with his calculations. This was done back in 2008 and he has box loads of it.
I guess it would be a mission to post each page. Well I managed to get some pics of the paper work i know to some people it wont mean much however to some its priceless.
Enjoy
Makes my head hurt doing that kind of maths! Someone should teach John how to use MS Excel. Im sure he could then create the mother of all engine calc spreadsheets.
I noticed the mentioning of a water/meth injection system too. As your already running with 12 injectors, where will you be putting the injector nozzles? Just after the BOV's and before the plenum, or are you modifying the plenum further to support direct port injection as well?
Hey Ian,
John can not go near a computer i have tried many times they just die everytime he touches them. Yes the calculations are done for everything on and in the motor.
The water methanol injection nozzel will be placed infront of the turbo. John has said this will help cool the charge and increase the pressure ratio of the turbo as you now are compressing air with liquid vapour ( density increase = higher turbo pressure ratio).
I will be using a snow performace setup that will be modified.
Cant wait to see the final results on this build Bobby..its awesome to see this level of detail , custom fabrication , not to mention the dollar amount.thumbsup.gif
I hope this can really achieve everything your hoping for..look forward to the next installments.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
