Gday guys (an girls)
Well the GTR has been sitting in the garage for a bit to long now (injectors 5 & 6 are leaking to a point where it misfires and becomes undrivable).
So i went onto Nengun performance to order some Sard 700cc Injectors and they are now saying that they are discontinued, is this the case and does anyone over here do them for a price that was close to the $650 mark (price i got quoted to ship them over here)?
I might a well tell you the current setup to make giving advice a bit easier.
RB26DETT out of a R33
2x GT2860RS -7's
Yellow Jacket Coilpacks
And the current injectors are i think are Nismo Yellow 555cc
Its running 297rwkw's on 18PSI
Dont know much else about the internals except that its done around the 65,000Km mark
Now for the questions
Is it worth buying new injectors?
Can you rebuild these injectors?
Are the replacment SARD 800cc injectors overkill for my setup?
What im currently thinking of doing
Cant decide which one to buy
SARD - 800cc x6 - Top, Low Impedance, 2 Hole, Yellow - Green, Time 1.10 msec AU $ 675.86
Or just buy what it has already Nismo Yellow - 555cc X 6 Injectors AU $ 877.88
My other question is why would i pay around $200 more for 245cc less??????
I am looking at running the same power but would i be able to do this with the SARD 800cc injectors or would it end up overspraying the fuel being a 800cc??
I dont really know to much about injectors yet but would apreciate any advice
Sorry about the Essay size post i just like to give you guys the most information possible when asking advice.
Thanks in advance
https://www.sau.com.au/forums/topic/355592-sard-700cc-discontinued/
There is a minor difference between the 700 & 800 - its spray pattern as the nozzle is different.
Apparently the 700's tune ever so slightly easier, but its not a show stopper.
HOWEVER i assume you have a tune that matches your 555's?
If so, simply getting 555's will be much cheaper than going for a dyno/retune by putting in different brand & size injectors into it.
Whilst they will cost more, it'll workout cheaper overall as its a simple replacement.
what ecu do you have? if your injectors are yellow you most likely have standard GTR injectors mate. I would say just buy a couple of standard injectors to replace the leaking ones, remove the other 4 as well and get the whole lot cleaned and flowed.
the sard 700cc injectors are a great injector mainly because the operate with a response time close to standard (0.65ms) the 800s are 1.15ms. it's not a big deal and it's generally the case that the bigger the injector the longer the lag time between open and closed (it's inevitable) but the sard 700s were (are) a good performer.
if you're making 297rwkw your standard 440cc injectors will be maxed but as long as you are happy with the set-up then by all means just replace them and leave it as is. if you change to ANY other injector size you will need the car re-tuned. yes if you slot in some 800cc injectors the car will badly overfuel hence the need for re-tuning.
16600-RR543
Part number for yellow nismo 555's for RB26
no. they don't. that part is for RB25 SIDE FEED INJECTORS. which are yellow and are 550cc but ARE NOT RB26 injectors. RB26 injectors standard are yellow, are top feed, and are most likely what this dude has (as sean pointed out). very unlikely someone would convert their RB26 to side feed, high impedance injectors and then buy the most expensive injectors around to gain 110cc... it would be like a $1500 exercise when they could buy bolt in sard 700s for around $700.
I'm still wagering this bloke has stock ecu and stock injectors.
Nengun must be wrong then... Usually the part numbers are spot on.
Lists BNCR33 as that number for 555 :ermm:
Yeah, the leaking is a telltale sign.
Also BB I thought standard injector latency was 0.77, not 0.65....
fark you are challenging my memory!!! off the top of my head standard was 0.4X (0.4something) and sard 700s are 0.65. it's easy to find, plenty of tables around with lag time figures for common injectors.
trust me they are wrong. there are no yellow 555cc top feed RB26 injectors I know of. that part number is definitely for the yellow nismo side feeds used on ECR33 RB25. nengun is actually wrong more often than you'd think with mix-ups between GTR/GTST etc. it happens to everyone a bit though.... people often assuming BCNR33 just = R33 etc.
you are right. standard RB26 is apparently 0.77. got me fked now how the sard 700s manage 0.65 but I remember it clearly having sold and fitted so many to various GTRs over the years. I could recite sard injector lag time figures in my sleep...
Sorry for the late reply guys,
to my knowledge it has some form of nismo ecu. I think I was the sort that replaced the factory one and not one that piggy backed.
As for the injectors I will have to pull one out for you and take some pictures so you all have a better idea. I'm pretty sure they were yellow ones. And yes I was told they were at there max so they prob are the factory ones.
So If I was to put the same ones in again I wouldn't need a retune?
And does anyone here have any good standard injectors for sale?
If so are they hard to install?
Cheers
Correct - you're replacing like for like.
Here's my DIY on GTR injector installation, its pretty easy: http://www.skylinesaustralia.com/forums/topic/285621-diy-gtr-injector-replacement/
nismo ecu or not you cannot change injector size without a re-tune and no nismo ecu is tunable here in aus (or anywhere else for that matter, they are set by nismo and that's it). 100% as long as you fit the same size injectors you have now you will not need a re-tune.
it's not hard to change injectors, basically release the pressure from the rail, then start unbolting stuff.
my advice would be pull out one of the working, non-leaking ones and get it cleaned and tested. shouldn't be more than $20 or $30 for 1 injector. they will tell you what it flows (i'm betting standard 440cc). if they are standard just buy some used standard ones, get them and the rest of your old ones cleaned and flowed too then install them. there should be plenty for sale in the for sale section. usually pretty cheap too. you can also use RNN14 GTI-R SR20DET injectors (no real advantage except they come in 4s so you don't have to buy 6). cannot use any other SR20 inecjtors though.
i bought the 700cc sards and they are direct drop in, i did not buy the 800cc sards as they use different plugs and i rather NOT rewire them if i have the choice and apparently the fuel rail spacing needs to be modified too
shame you cant get the 700cc's anymore? CJ motor stock them im pretty sure.. do some more hunting! :)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
