Hey guys can some one please identify if this is the stock cat that I have under my car?? I had a full 3" exhaust from the turbo back when I bought it (and still do) so the guy who did the exhaust (previous owner) couldnt have left the cat as a stocker. I really hope its not the stock cat.
Can someone please identify if I have the stock or aftermarket cat, thats the only pic I have.
thanks
Edited by rondofj
https://www.sau.com.au/forums/topic/356209-stock-cat-or-not/
It could be gutted who knows, best to drop the catback or the frontpipe and shine a torch through, it could even be a 2.5" cat.. or it could even be a de-cat with a heatshield to disguise it, really should take it off.
Weld in quality High Flow cats with metal substrates (so they dont burn out) are around the $170 mark on ebay.
http://cgi.ebay.com.au/Universal-Catalytic-HIGH-FLOW-200-CPSI-converters-/130485317656?pt=AU_Car_Parts_Accessories&hash=item1e6187f018
If you want to save your dosh, gut the stock one.
It sort of looks like its stock, take it off and check if its 3" and not smaller and bolted to your 3" system.
Thanks buddy, by gutting, do u mean remove the internals or 'guts'? Didnt think it would have any as its internal pipes supposed to be a 'free flow path' for gasses with the bits around it..
Weld-in cats I assume would be expensive as I wud have to have flanges welded etc??
Gutting removes the internal honeycomb which is a restriction.
Gutting is highly illegal, if you get slapped with a EPA test you will need to get a stock cat to pass the test and stay out of trouble.
For weld in cats they cut the old cat out, keep the flanges, and weld the flanges onto the new cat.
Or get 100psi one from here:
http://www.venomexhaustworks.com.au/products.html
Gutted cat, apart from being illegal, can make your exhaust sound cr*ppy. Splash out on a quality metal one and it should last for years.
Sweet, I'm lookin at these from justjap -
http://www.justjap.com/store/product.php?productid=18070&cat=275&page=1
http://www.justjap.com/store/product.php?productid=16436&cat=275&page=1
Both $175 each - maybe go with the xforce one? f**king cat, another hassle to sort out.
cheers
Does it?? Damn I have to change it then, still not sure if it is stock - why would anyone change the whole exhaust and leave the stock cat, is the stock cat 3" hi flow or smaller?
My car was meant to have a full 3" system, on closer inspection it had the standard front dump, 3" dump, standard cat and 3" cat back, no idea why ppl would do it, its just a waste of money!
dont gut your cat you made need it in the future, just put it aside for when you may need it.
The cat you get depends on how much power you want, i have a jjr xforce, was fine for 200rwkw but now im looking at pushing it to 300rwkw its time for a new one.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
