Has anyone thought of using one of these to run more than 1 component into this tuner? This way you could run a dvd player, iPhone, reverse camera and fit this unit neatly in the top glove box and switch between them.
http://www.ebay.com.au/itm/4-Port-RCA-AV-Selector-Audio-Video-Switch-Box-HDTV-906-/170547216551?pt=LH_DefaultDomain_15&hash=item27b56800a7#ht_2155wt_922
  • Replies 144
http://www.ebay.com....7#ht_2155wt_922
That would work well except it wouldn't automatically switch to the reverse camera if it was on a different input at the time. Otherwise a very cheap way of sharing the input between multiple devices.
A few of us have looked for similar devices previously, but nothing as good as that for so little expense has been spotted before. Nice find. :thumbsup:
Yeah Im thinging of using this to run the iPhone and dvd player under the front passenger seat as its already there. Im grabbing a tv tuner from Brad tomorrow so looking at what else I can use to hook it all up.
What are people using to connect an iPhone? are they using a spec dock or just an Ebay iPhone to RCA with powered wires to charge the phone then run it into the console?
That does look to be quite good but todate all the ones I have tried have not been that crash hot.
With Leon's Tuner you have 2 input sources (1 x RCA & 1 x USB). You can also rig an additional input directly for the reverse camera to the OEM tuner.
Not sure how many devices you want to run but that would give you, TV tuner, Reverse camera, Iphone plus hard drive with all your movies and music.
Cheers
Andy
I like my setup for iPod, just using a USB cable direct to the deck. Works well!
Didn't get a chance to check the iPhone stuff today but sounds like you don't need to now :thumbsup:
Is the USB limited to a certain size hard drive? My JVC double DIN dvd deck can only read from a max of 4gig via usb.
Not 100% sure on that as I don't have this Tuner in my car but an older Asuka one.
Leon, may know the answer to this.
I do know that it has to be a PC formatted hard drive.
I personally don't use my DVD headrests very much at all, just the kids do. When I am in the car I just use the iphone for movies and music.
Cheers
Andy
Cheers
Andy
How/what are you using to connect the iPhone?
Cheers
Spec doc was stupidly expensive when I looked at it, but it is nice. Just do a google search for Spec Doc, they have photos on their web site.
Fat32 isn't more limiting, as Fat32 limits file size, not sure it limits partition size?
Hi Everyone
Getting back to the original point of this thread, I just picked up another shipment of 20 tuners from the PO.
I will message everyone that has contacted me in the last few weeks & confirm delivery info.
I was told that these ones were a different colour (black, not gold), slightly smaller & included an SD card slot. Well, the manufacturer must have found some more of the original housing because these ones are exactly the same as the last lot.
So, please accept my apologies if you were hanging out for an SD slotted black tuner of more petite proportions.
Cheers, Leon.
What model spec dock is it? I may grab the same. Any pics of it installed?
This is the correct Spec dock for our cars; http://stores.homest...V2AV/Detail.bok
Cost was about $190Us including freight and at the time i bought mine that was around $220 ozzie.
I just enjoy the fact that phone is always charged and music or favorite movie is always at hand.
No gear knob Andy? Did you take the picture before it was put back together or are you going for that "just stolen" look :happy: .
Going for the Fully Sick look... lol
Nah, just had not put it back on yet..
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
