  • Replies 80
A cheap trick you could try there is to under drive it by putting on a larger pulley. I am pretty sure the Neo has a small diameter pulley for the water pump. You could try fitting one from a 32GTST or 32GTR which, if I'm not mistaken, is larger in diameter? which should slow it down a tad.
Worth a try if all else fails and certainly cheaper than pulling the head off....which should be the last port of call
heads off... motor is mint. good to see with the thrashing its had with 360 + rwkw on stock motor and e85 that the bores are perfect, pistons perfect and so is the chamber and valves.
no fault with HG or anything.. gonna crack test the head tho might still b a slight fault thats hard to see
Would the engine oil be milky yet if it was HG fail? and would the water have oil going into it?
are you bleeding with the heater on to open those pipes up (if relevant / still have heater pipes)?
regarding pump stress going through many cores - I wouldn't worry about that - I have a standard rb25 and its pumping water to the rear of a buggy through like 8 metres of pipe total and about 8-10 bends, also the rad is sitting higher than the engine so it has to pump all the way up there. does it fine :D
if the water level is going down before its going into overflow bottle, it has to be going somewhere, no leaks around back of block or near the inlet mani area? blowing any smoke?
edit: looks like i missed a few pages of the thread, woops. haha
Edited by turael
you can have head gasket issues without leaking oil into water and vice versa. no its not blowing any smoke and no leaks. its actually pushing the coolant OUT of the rad into the overflow and not sucking it back in.
dropped head off to Rhemac and they seem to think its highly likely theres combustion pressure eascaping into a watter gallery under high load.
had the same issue with mine, turned out to be a stuffed clutch hub on the fan. Coolant would spew into overflow and boil, then suck it all back in.
How old is the one on yer car?
ive changed it several times.. but yeah you could be onto something. i wanted to do AU thermo fans but have no room to do so :(
Only reason i found out was it was happening to my old 20, then replaced it with the 3lt and the same symptoms happened with the new motor. No airflow through a fresh system..had me wondering. Only old thing i reused was the clutch.
Factory cooling works fine though for a lot of thrashing as long as its left intact, shroud included.
yeah only reason i cant fit anything atm is due to the 52mm rad... might go back to a stock GTR rad and see how that goes.
at the end of the day at least ive done MLS and ARP bolts so motor should be even more reliable then it already is lol.
if i still cant solve the cooling issue... i'll run the radiator in the boot. and run a massive ducting system with huge fans pulling the air thro lol
hmm looks like a little pinging at some stage, obviously not too bad though.
I have finally sorted the cooling problems in my race car, no problems running indefiantely at race speed these days (1hr +).
I am not sure what fixed the issues but here are the things I did for cooling:
standard fan and shroud
n1 water pump
greddy overdriven water pump pulley
new viscous coupling for fan
china 40mm radiator
1.3 bar radiator cap
nismo thermostat
with all of those things, water temps were just acceptable. when it last ran in that spec it was overheating badly but that turned out to be a water leak (so farking annoyed I checked everything except a simple pressure check)
since then i changed to:
pwr twin pass radiator
moved oil cooler from in front of the radiator to the ps guard.
shrounding the radiator to the chassis and front bar entry
now it is absolutely fine. in fact i changed back to a standard thermostat because it was running too cool for my liking.
they are the facts. my guess is the most important of all of the changes was proper ducting from the front bar entrance to the radiator. if i was air, i would find any way to go around the radiator instead of through it. no reason to think the pwr radiator was any better than the china one, especially not for $800 and 2 mistakes between the order and what I received :mad:
wait wheres the pinging? that white shit on the crown of the piston is just powder.. it wipes off. think its moisture from idling befire i ripped the head off.
but thanks for the list... i will carbon copy it (90% of the way there as it is) and see how i go
We had a chinese aluminium radiator in a 31 GTS-X with RB25 track car, exacxtly the same thing, blowing out water from overflow, over heating, thought was head, or gasket, or a million other things.
Do you know what it was in the end? The radiator cap neck was taller than the STD item, so STD or skyline aftermarket radiator caps wern't actually sealing off, i noticed this and put a thick o-ring in there for tempory measures (which worked), have since made up an alloy ring to sit into neck, so that there was pressure on the spring and it could seal. Simple Re-bleed, end of problem.
This may be completely unrelated and it maybe is your head, but worth a look
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
