Hi all im after some info / help
I have a R32 GTST with a RB26, gtr rear end, gtr brakes, rb25 gear box R34 i think or rb30T built with gtr gears.
Im wanting to make it a 4wd more traction and better take of etc.
the car is a track car and pretty much stripped out.
was thinking of getting a gtr and swapping all the good bits over but dont really want to wreck a gtr car.
is it a massive job.
help or quote will be great
https://www.sau.com.au/forums/topic/356419-r32-gtst-into-a-4wd/
4WD is not the answer. A better setup is.
RWD is light, is fast - you just need to know how to drive it and have the setup to support.
R32 Gts-t 360-380rwkw IIRC. Full prepped race car, and utterly insane
Fastest car @ calder weekend just gone
Hopefully it makes it to the SAU Nationals ;)
I love the bit 30 sec in, when he lines up the S14 over the hill; looks like the S14 shifts into reverse, he it passes so quickly :worship:
What a riot.:thumbsup:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
