  • Replies 61
I can't drive a drag very well at all... and with my brother with a stop watch in the passenger seat I managed to do mid 9 sec 0-100. RB30 manual box, Rb25de 240,000kms. I barely got any wheel spin and I would rev it up a bit to start but the revs would drop down to like idle and then climb lol. I was too nice to it. But its sounds like considering I was a bad driver 9 1/2 sec is pretty good lol.
I am sure it did it faster when it was auto simply because it would start better (since the auto slips kinda). I guess mid 7 or 8+ as an auto. Sure did feel fast off the mark as an auto and that I think is where most time is lost unless I am mistaken.
cheers
Edited by senilykSkylines
Ok, thats it.
Actually bothered to do this.
10 secs, auto NA SR20, simply foot down in drive, in straight auto mode. Filled to the brim of fuel, full weight nothing taken out. 218k kms on the clock.
http://www.youtube.com/watch?v=dzDd21y7nek
Edited by Ten Four
Hi guys, what would be the 0-100km/h time for a N/A nissan skyline manual coupe (untouched and unmodified)? I did a search around these forums, google etc couldn't find anything.
EDIT: Model is R34 25GT
Ok, thats it.
http://www.youtube.c...h?v=dzDd21y7nek
you didnt really answer his question...
he drives an R34 with a RB25DE in it . im also guessing you were not driving a skyline.
so
differnent car, different motor
HOWEVER, that time would be roughly the same.
so
/facepalm
RB25DE Neo 200hp at fly yes? Manual = faster too with launch.
SR20DE non VVT AUTO 135hp @ fly..
Someone seriously can't drive. They SHOULD easily get high 7s (good driver) to mid low 8s (average performance car driver)
Edited by Ten Four
Cause there are people in here with R34s saying 10+secs for a R34 to 100.
If ^ car can do 10secs, then there are lots of shit drivers.
Quick youtube search. 8 secs, no launch.
Now close topic as question has been answered.
Edited by Ten Four
/facepalm
i originally said this becausethe SR20 (depending on the car - List of Cars With The SR20) you are capable of running low 8's
Edited by ML73ZR
Man the best I ever got from my auto turbo was ~7 seconds, I must be a really shit driver...
<hangs face down in shame>
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
